Fuel gauge issue
Started by Paul1965, July 06, 2014, 03:29:49 PM
Paul1965
So yesterday my gas gauge was bouncing ALL over the place on my ride home. After a fill up it got even worse until it eventually stopped altogether. Thinking it had come unplugged under the seat, I checked the connection today to make sure it was tight. Turns out that wasn't even the issue, here the needle had bounced around so much that it's now stuck on the wrong side of the stop pin. Has anyone else had this happen, and will I be able to fix it? I'm not worried about taking it apart as I've done that before, I just don't want to waste my time if the gauge is damaged beyond repair now.
1978 Yamaha 400 Sold
1984 Yamaha Maxim 400 Blew up
1982 Yamaha Vision Sold
1983 Kawasaki GPz1100 Sold
1984 Yamaha FJ1100 Killed it
1991 Yamaha FJ1200 Sold
2009 Triumph Sprint ST Sold
2014 Triumph Trophy SE
Quote from: Paul1965 on July 06, 2014, 03:29:49 PMSo yesterday my gas gauge was bouncing ALL over the place on my ride home. After a fill up it got even worse until it eventually stopped altogether. Thinking it had come unplugged under the seat, I checked the connection today to make sure it was tight. Turns out that wasn't even the issue, here the needle had bounced around so much that it's now stuck on the wrong side of the stop pin. Has anyone else had this happen, and will I be able to fix it? I'm not worried about taking it apart as I've done that before, I just don't want to waste my time if the gauge is damaged beyond repair now.
Paul,
You can lift the needle back over the pin, into the operating range; just do it carefully.  Chances are, the needle was bouncing due to a flakey ground, rather than the gauge or sender unit as being the culprit.  Trace out the ground lead, and you will probably find rust or a loose screw at the frame.  You can always simply install a new ground wire with the old one, to be sure.  If that does not fix the problem, clean up the sender unit, or try a good one.
FJ1100mjk
Iron Balls #00002175
www.ironballs.com
Paul1965
I was able to fix it without even taking it apart. I took a few strands of copper wire and wound them together, then threaded them through one of the clock set holes in the lens. All I had to do was catch the bottom of the needle and pull it back around and the gauge is back to normal  :good2:
Paul1965
Quote from: red on July 06, 2014, 04:38:48 PM
Paul,
Thanks for the info Red. I'm pretty sure it's a sender issue. Cruising down the road I can rock the bike side to side and get the needle to bounce even worse. Plus I didn't have this issue until I did the tank swap. So next time I'll wait to fill up and pull the sender out and see if there's anything I can do.
Paul1965
I think my issue was actually the harness connection under the seat. I made sure it was tight yesterday and noticed no bouncing at all on the way to work today. So tonight I'll zip tie the connector so it remains tight. Thanks everyone for the help....
