Gas mileage poll
Started by Paul1965, July 05, 2014, 07:08:36 PM
What kind of gas mileage do you get?
25-30 mpg
2 (5.1%)
30-35 mpg
3 (7.7%)
35-40 mpg
10 (25.6%)
40-45 mpg
18 (46.2%)
Who cares just ride!
6 (15.4%)
Total Members Voted: 39
Voting closed: July 10, 2014, 07:08:36 PM
theLeopard
Quote from: FJmonkey on July 06, 2014, 07:49:06 PMNow with UNI's, Suppertrap slip-ons and proper jetting
When the time is right, can I ask you for a tutorial on increasing my performance with said upgrades?
I'm not ready now, bike runs good and I'm busy with school, but afterwards I would like to upgrade.
1992 FJ1200
Quote from: George"It is What It Is Until It Ain't Anymore"
Zwartie
The mileage on my '92 FJ1314 varies between 35 and 43 mpg (US). There seems to be a correlation between the twist of the right wrist and the fuel gauge. Not much difference between this FJ and the '86 FJ1200 that I had from '94 to '05. The best range (calculated) that I ever got to a tank was just over 250 miles (400 km).
Zwartie
Ben Zwart
London, ON
1992 FJ1200
1977 KZ200
Mileage on my '84 with RPM's 1350cc engine, UniPods, 42.5 pilots, 122.5 mains, needles up 1 notch, 5 degree ignition advance with 18/40 gearing is ~33 on the low side to 36mpg on the freeway.
With 40 pilots and 117.5 mains I got as high as 41mpg, but the engine was not happy......I like happy.
Mileage on my '92 with DynoJet stage 3, UniPods and Kerker 4 into 1, 5 degree ignition advance, 18/40 gearing is ~42 mpg all day long.
rusjel
My '88 with stock everything except slip ons and jetting adjustment ran in the low 40s ( US), rising to high 40s as the engine got older and looser just before it started eating oil at the 120 thou mile mark then steadily got worse till I replaced it.
The 92 with stock everything was around the low 40s the whole time I had it.
The engine was such a torque monster stock or near stock I wondered why anyone would want to mess with it. Then I rode Arnies. Yeah it was worth it.
No good deed goes unpunished
GhostMerc
I get about 40 under normal, town, and aggressive riding conditions.  I've seen as much as 59 a couple of times.  This is at 60mph ~3500rpm  for over 100 miles or so.  I also only weigh 135lbs, I'm sure that has something to do with it.  I've got a Dyna 2000 ignition and Supertrapp exhaust.
1986 FJ1200
2015 FJ-09
the fan
My SV1000 gets around ... not enough.
This may have something to d with my right wrist  :yahoo:
Right Henry? Dean?
Quote from: the fan on July 08, 2014, 10:21:47 AM
Don't think its you.  I have a Cagiva Navigator with the TL1000 engine and it doesn't match the FJ for mileage.
As a matter of fact, neither does my Aprilia Shiver and that's only a 750cc V-twin.  FJ's hard to beat.
Flynt
Quote from: Pat Conlon on July 07, 2014, 10:32:52 PM
Same engine, 39mm FCRs, 18/41 and I get ~31mpg in daily use as a commuter ranging to ~36mpg at ~6000ft elevation riding in the Sierras last week.  This was also my first >4,000ft elevation run since the dyno tune of the FCRs and the bike ran great up to ~7,500ft on the passes.
Touching on another point that has been discussed here...  my FCRs were tuned at sea level effectively and ~75F.  I've run them in ~45F at sea level to >100F at 7,500ft with mild performance impacts (richer cold, leaner hot and high altitude, but no knocking or anything destructive).  I don't believe these carbs on an FJ are nearly as finicky as one might think...
the fan
Quote from: Arnie on July 08, 2014, 10:31:05 AM
That one was more of an inside joke.. I ran out of gas on the cherohala two rallies in a row... come to think of it one of those was on my YZF600....
With the temp threshold reprogramed on the ECU in Randy's fuel injected system, I wonder what kind of mileage he is getting?
Bminder
Quote from: GhostMerc on July 08, 2014, 07:51:30 AM
I get about 40 under normal, town, and aggressive riding conditions.  I also only weigh 135lbs, I'm sure that has something to do with it.
Hmmm... I'm almost two of you.  :sorry:
Guess I should be happy with 35 mpg.
Billy Minder
92 FJ1200 ABS
Bones
My FJ is like a hybrid compared to the Kawasaki 500 triple 2stroke I owned when younger. That thing was petrol cooled I think, and would only get 20mpg. A lot of fun though. :biggrin:
93 fj1200
79 suzuki gt250x7
Quote from: Bones on July 08, 2014, 02:50:23 PM
My H2 used to get about 23.     :empathy2:
+1 on the fun factor, though...  except for the shift pattern.    :wacko2:
Quote from: not a lib on July 08, 2014, 03:01:33 PM
...and until you wanted to go around a corner....that flexi-flyer frame was frightening :shok:
Quote from: Pat Conlon on July 08, 2014, 03:50:50 PM
I always felt that was overhyped.
The shocks were what was really scary... :shok:
