Tire change tip
Started by jamesearthdrum, June 02, 2014, 04:31:46 PM
jamesearthdrum
peace:)james
~~~friederich nietzsche ~~~
Zwartie
Done it a couple times now and it works great! Purchase my tires online, install and balance them myself (or with a friend) and figure I save about $150 per set.
Zwartie
Ben Zwart
London, ON
1992 FJ1200
1977 KZ200
jamesearthdrum
You can remove them this way too!
james
peace:)james
Quote from: jamesearthdrum on June 02, 2014, 04:39:52 PM
james
Nawww. break the bead, both sides, cut the side wall (with a tool like this Multi-Tool, with a smooth blade, remove the carcase, pull off the beads. All done...
jamesearthdrum
Thanks George,
                 I missed that thread. I made a bead breaker from 3" channel iron. Same idea as the 2x4 under the car. Welded on a piece of 1/4" cold rolled hammered into a curve. It's heavy enough that I need very little pressure to break the bead. FJ is getting new shoes before the ECFR. This will be the first tire change since loosing my workspace so it will be very handy.
peace:)james
Burns
Just read this.  WOW what a great tip!
Zwartie
Just put a set of Michelin PR4's on this past week. As I was cutting the old front tire off it came to me that this process is "stupid easy". Why oh why would I have anyone else replace my tires unless I didn't have the time or had excess money I wanted to part with?
For the record, I got approximately 15,500 km out of my previous tires - Michelin PR3's. The rear was completely done but the front looked like it had a at least a 1,000 or more km left in it. The most I think I've ever gotten out of a set of tires. Most impressed with the Michelin's so far. Will see how much I get out of the PR4's.
Zwartie
Ben Zwart
London, ON
1992 FJ1200
1977 KZ200
wirehairs
Quote from: Zwartie on June 02, 2014, 04:38:50 PM
I have yet to install a tire myself; $20 a tire nearby is pretty cheap.  However, I'm curious about the balancing part.  How do you do that?  Do you use those internal beads?  http://www.amazon.com/TyreBeads-Tire-Balancing-Beads-Motorcycle/dp/B00C8UKFIM/ref=sr_1_1?ie=UTF8&qid=1434037092&sr=8-1&keywords=tire+balance+beads
No Beads....... Harbor Freight wheel balancer. http://www.harborfreight.com/motorcycle-wheel-balancing-stand-98488.html.
Or you can make your own version. Check You Tube for other idea's.  I have a Cycle Gear down the road also that will do them but I prefer to do my own.
