what carb mods do i need to do?
Started by josh_smith91, May 31, 2014, 10:44:04 AM
josh_smith91
decided to put pod filters on after i get done cleaning the carbs because the airbox was a major PITA. what im wondering is with putting on pod filters with a stock exhaust what carb mods will i need to do? different size pilots, adjust mixture screws anything i need to do or with the stock exhaust still will it be ok?
1985 Yamaha FJ1100
FJ1100mjk
Review the information under "Jetting" at this site...
http://Fjowners.wikidot.com/pods
Good luck.
Iron Balls #00002175
www.ironballs.com
If you only add pods you may not need to re-jet. Your pipe is the other restriction to what the jets needs. If you also change your pipe then the open system will need more fuel..
