Stock air filter holders / keepers / clips
Started by Bob, May 26, 2014, 08:11:33 AM
Bob
During a major brain fart yesterday I discarded the things (clips, keepers, holders) that hold the stock air filter in place (I have an oil based filter and was doing regular maintenance). According to every web site I checked the part is no longer available (listed as "Air Cleaner Case" 36Y-W1441-00-00).
I'm sure I can make my own, but it would be nice to have the OEM parts.
So, anyone out there who removed their stock air box have these clips?
After 18 years of some non-trivial mods I screw up on something like this  :ireful:
Bob
Bob N.
'93 FJ
'17 V-Strom DL650
Whitby, ON
Getting it in before anyone else does (....)
Tossthewholeairboxandgetunipodsfromrandy!
Totally unhelpful, but this way it's out of the way and done, and everyone else can be helpful.
Quote from: andyb on May 26, 2014, 08:14:00 AM
I am number 2 on that one!!!! +!
Hey Bob, someone here has them, if not, I might have some, but I'm away from home right now...
I'll check back in a couple of weeks....WCR Rally time!
Hersey289
Hi Bob,
I may have an extra set for you. I'll check tonight and let you know.
Rob
+1000 to this suggestion Bob. Have a look at my link here and see what I found in my carbs when I thought the standard airlfilter was sealing properley.
http://www.fjowners.com/index.php?topic=10458.msg101394#msg101394
Bob
Quote from: X-Ray on May 26, 2014, 06:41:16 PM
Ya, replacing the old air box is probably the way to go... I just hate being defeated like this.
And I figured my oiled air filter was rare; don't see it talk about here much. I liked that.
Bob N.
'93 FJ
'17 V-Strom DL650
Whitby, ON
Hersey289
I do have an extra set of airbox of clips. Like the others, I don't use the airbox and use unipods instead.
Rob
jvb_ca
Bob, I am pretty sure I still have mine as well along with the entire air box. If you don't get them from Rob, your are welcome to these.
Cheers...Jake
Cheers...Jake
86FJ1200
Ontario
Bob
Well, uni-pods are probably in my future, but for now Rob will be sending me the air filter clips.
Huge thanks Rob  :good2:
Bob N.
'93 FJ
'17 V-Strom DL650
Whitby, ON
Charlie-brm
Just installed this one a few weeks ago. I "lose" the wedges just about every time I pull the filter; then they show up on a bench or next to a drain pan somewhere the next morning after my brain had some rest.
1979 XS750SF - 2005 to 2012
Bob
Quote from: Charlie-brm on May 28, 2014, 09:42:59 PM
... Just installed this one a few weeks ago. I "lose" the wedges just about every time I pull the filter; then they show up on a bench or next to a drain pan somewhere the next morning after my brain had some rest.
Mine were flushed down the toilet.  Don't ask.
Bob N.
'93 FJ
'17 V-Strom DL650
Whitby, ON
