Engine rattle
Started by Ront, May 11, 2014, 07:51:02 PM
Ront
Hi I was riding my '86 fj1200  today that I've been working on all winter when the engine developed a loud rattle that increases with engine revs. Before this the bike ran like new with no engine noises. Can't hear rattle at idle. Sounds like top-end. Bike has 27,000 miles.  Any ideas or responses appreciated     Thanks
Punctuation could use some work. Needed a few minutes to get the problem statement. So this noise started suddenly? Or did it build up as you rode along? No noise when at idle kind of rules out valves. In the last day or two a member posted up finding his cam bolts loose. Not that I am suggesting you need to pull the valve cover right now. More information would help. Is the sound more Left side or Right side?
Exhaust header pipe ?
Ront
Didn't know my punctuation was being judged.  Can't tell which side rattle is on. Could it be cam chain tensioner failed?
Quote from: movenon on May 11, 2014, 08:18:48 PM
Single wall pipes on 86/87...
Quote from: Ront on May 11, 2014, 08:31:31 PM
Not judged, you are asking for help/advise, making it more cryptic means more work for the generous (free) help you will get here. Help us help you.
Quote from: FJmonkey on May 11, 2014, 10:19:48 PM
You are correct.  His is an 86  :dash1:.
This is a good suggestion and an easy one to eliminate. I have seen this a few times and read of it here as well. The header pipes can come loose (or the gaskets compress) and it presents itself not as an exhaust leak, but a rattle.
The header pipe "jumps" out from the head when it fires on that cylinder and snaps back in with a bang. It mimics a serious engine rattle very well.
Easy to check, just make sure the header bolts are all tight - NOT TOO TIGHT though.
Quote from: movenon on May 11, 2014, 10:52:07 PM
George, your heart is in the right place, keep the suggestions coming... Even a blind squirrel finds a nut now and again...  :mocking: Nothing but love for you George, looking forward to seeing you soon at the rally...
Quote from: FJmonkey on May 11, 2014, 10:57:29 PM
OK how about his chain :).. Also looking forward to seeing you and everyone else.  Off the subject a bit,  but do you know anyone looking for a 89-90 shock link that wants to covert to dog bones?  One of the local wreckers here has one for 18.00.  Its on e bay but no bidders yet.
Quote from: movenon on May 11, 2014, 11:02:17 PM
I paid twice that for the 89' shock link in my garage. If you want your 84/87 to have dog bones, this is a good deal...
Quote from: FJmonkey on May 11, 2014, 11:12:23 PM
Its the hard part to locate if anyone wants to do the conversion.
Have a good one
George...buy it...do it now. They are rare as hen's teeth....seriously.
Someone who has a '84-87 and wants to convert to dog bones needs this link, actually called a "Relay Arm"
You will make someone's day....
I took me almost 3 months to find mine when I did my '84..... Damn inconvient.
BSI
Quote from: Pat Conlon on May 11, 2014, 11:46:49 PM
Pat...the last 2 times you suggested someone 'buy it'...well I did and was happy I followed your advice so here we go again and I'm on it...thanks  :good2:
92' FJ1200
86' FJ1200
86' FJ1200 - just bought-not started in 2 yrs
04' Suzuki DRZ 400S - cornering on knobbies
76' Husky WR250 - bought in 81', needs lots of TLC
skymasteres
This might sound stupid, but check your oil level. If it's really low the engine will rattle like crazy....
