NOISE COMING FROM MY 84 FJ
Started by Brian, April 24, 2014, 06:34:29 PM
Brian
Gday Guys , i have just noticed a high pitched screaming coming from my bike while riding ,it comes & goes frequently  it sounds like its coming from the engine but when i pull clutch in it stays there until i roll down to about 10kph then stops suddenly ,now its gettin colder its happening more often this would have to be a wheel bearing wouldn't it ?
does anyone know the part number of front wheel bearings for fj1100 so i can purchase locally
& have them quickly ,i have the seals
any help much appreciated
cheers Brian
Dont you just love that special place of Beer,Bikes 'N' Bullshit !
Hey Brian, disconnect your speedo cable at the wheel and pull your speedo cable out of the sheath, hook it back up empty, go for a ride and see if the noise goes away....
You might have the Death Howl...
Tiger
 :hi: Disconnect your speedo cable and take your FJ for a wee spin around the block.......is the noise still there ?? or :scratch_one-s_head:
John.
oldktmdude
   G'day Brian, disconnect your speedo cable at the wheel and go for a test ride. Make sure that you tape the cable end so you don't loose the inner cable. Front end squealing or screaming noises are usually associated with the speedo. If it's still making the noise, check your wheel bearings.  Pete.
1985 FJ1100 x2 (1 sold)
2009 TDM 900
1979 Kawasaki Z650 (sold)
2001 KTM 520 exc (sold)
2004 GasGas Ec300
1981 Honda CB 900 F (sold)
Tiger
 :lol: :rofl2: :rofl: Great minds think alike Pat/oldkt :good2:
John.
oldktmdude
      Seems like I'm about 3 or 4 minutes behind?  :unknown:  Pete.
2009 TDM 900
2004 GasGas Ec300
Brian
WOW , unreal how you guys think alike ill get out of my Pyjammies & do that,
if that is it do i just grease the cable or is it the speedo drive or head then ?
thanks for everyones input
Most likely the speedo, the scalded cat howl foretold the end of my 86' speedo. There is an outfit in San Diego, CA that repairs them. Or you could install a digital GPS unit, they look real slick...
Brian
Quote from: Pat Conlon on April 24, 2014, 06:39:58 PM
Yep u got rite guys, noise stopped when removed , rerouted cable & reconnected & noise gone (at the moment anyway) your all unreal
cheers Brian  :good2: :good:
oldktmdude
Quote from: Brian on April 24, 2014, 08:48:18 PM
Brian, the cable is probably due for some lubrication. Lithium grease seems to be a good way to go.
You wouldn't think such a wicked noise could come from a speedo cable.   Pete. :scratch_one-s_head:
2009 TDM 900
2004 GasGas Ec300
Quote from: oldktmdude on April 24, 2014, 09:00:16 PM
Exactly, you'd never think a cable could make that much noise, cause IT CAN'T.  The howling gods have just been stirred about, they'll be back.  Don't delay, make plans to get it fixed bore it goes Tango Utah.
