FZ1 swingarm/shock package
Started by FJscott, April 11, 2014, 07:45:07 PM
FJscott
does anyone know if the FZ1 Swingarm/rear shock combo has been done to our FJ's?
Scott
Yamifj1200
The FZ1 swing arm has been installed a few times here. I don't know of anyone that has used the FZ1 rear shock. I used a Penske shock that used the same shock ends as the stock shock had. I just had to modify the swing arm slightly to fit the fj frame and offset the rear suspension dog bones to line up with the shock.
Feel free to pm me if you would like any additional info...
Eric M
Damn, that a nice bike Eric....Taking good care of it are you?   Polished it lately?
I'm just checking....don't make me come out there...
Yamifj1200
Pat, I do still love the bike and am happy to take care of it. It will never be a show bike, its a rider that's still in good shape for her age. I don't think its ever looked better than it did down In Tellico plains, Hard to believe after dragging it through the rain the night before I woke to find it shiny as a brand new penny. Damn nice of the fellow that took care of that for me...
Eric M
yep first generation FZ1...... i dont know of anyone who has used the second generation FZ1 as a donor bike....... so far  :biggrin:
Yamifj1200
Well, nice pic, where was it taken???
Most photographed spot on the Blue Ridge Parkway...
Eric M
FJscott
Quote from: racerman_27410 on April 11, 2014, 10:16:00 PM
Very nice, did you use the FZ1 shock as well?
no the FZ1 shock was way too long.
yamaha fj rider
FZ1 shock 01-05 is the same length as the stock FJ shock. You will need to mod the top shock mount and the lower mount is to wide on the FJ linkage. FJ shock bottom is 27mm. FZ1 shock is 20mm. The spring is too light. You can switch to the stock FJ spring they are interchangeable. I used one on my 93 for several months with the stock FJ swingarm. Then upgraded to the shock from R6. Hope this helps.
Kurt
93 FJ1200
FJ 09
YZ250X I still love 2 strokes
Tenere 700
FJR1300ES
FJscott
Quote from: yamaha fj rider on April 12, 2014, 01:22:47 PM
Kurt
Kurt that is good info, thanks for the reply. for $150 I get a swingarm with chain guard,rear axle and spacers, shock and complete linkage from an 02 FZ1. ill have to sort out the upper shock mount it sounds like but that should be childs play.
Scott
yamaha fj rider
Scott if I can help just let me know. Please take some pictures for the forum. I had some but broke the screen on my phone and lost them before uploading them.
Kurt
93 FJ1200
FJ 09
Tenere 700
FJR1300ES
FJscott
Quote from: yamaha fj rider on April 12, 2014, 01:44:41 PM
Kurt
Thanks Kurt, appreciate the help :drinks:
Scott
fj johnnie
My 90 has the 02 FZ1 swingarm as well. I installed a Penske shock. The stock linkage will work, although the FJ linkage is wider than the pick up point on the swingarm of the FZ1. I had the FJ linkage milled down to line up perfectly with the FZ1 swingarm. Then stock FZ1 bearings and races can be used. ( in the FJ linkage ). I have been told that the FZ1 caliper must be used as it is somehow different than a regular blue dot? I cannot confirm this . Mine came as a complete swingarm wheel caliper rotor etc. It is a great mod. Sounds like a good deal. Also I added an offset sprocket and an XJR sprocket cover with the XJR clutch pushrod and shift shaft. Randy can get you these parts. Enjoy!!!
fintip
fjowners.wikidot.com
-ZAMM
IBA:54952
