carb settings.....
Started by mikedastonfj1100, April 04, 2014, 04:04:15 PM
mikedastonfj1100
Was wondering what to set the choke needle to... The needle that is on top of every carb body right next to the top cover....
"I live my life 1/4 mile at a time. Within that 10 seconds or less, I'm free".... Fast and the furious quote said by vin dessel...
That's the air idle screw and settings depends on your pilot jet sizes...
For stock 37.5 pilots, set the screws 3 turns out from fully seated. That will get you started.
Final adjustment should be done with the throttle 'blip test' on a warm engine.
Hope this helps.
mikedastonfj1100
Not the screw that sits between the carbs for syncing them together... Carbs are stock as far as I know... I'll upload a photo when I get home as to what needle in talkin about...
mikedastonfj1100
this is what I was talking about.... I was wondering what it is used for... and what would happen if it was all the way screwed in allowing no air flow through it... I have it 2 1/2 full turns out from fully seated... not sure if it is far enough out.....
Ugh... That pic is too small to see what you want to show... More detail please....
mikedastonfj1100
Quote from: mikedastonfj1100 on April 04, 2014, 09:17:15 PM
Small picture but it appears to be your fuel air screws. Basic setting is 2 1/2 to 3 turns out.  From there best to do a blip test and sync the carbs.
When the screw go's in it will lean out your bike and when you screw out it enriches the mixture.  It has a lot of effect from 0 to 1/4 throttle.
As a note when you are just cruising down the road at 70 mph you are probably only at 1/4 throttle.
Quote from: mikedastonfj1100 on April 04, 2014, 09:25:26 PM
I don't know how to make it bigger
Take a new picture of what you you want us to see...
mikedastonfj1100
I took these pics with a windows 8 phone....
mikedastonfj1100
As Pat said.
Dunno if you couldn't understand him, but it doesn't get any more clear than that.  3 turns out from gently bottomed is the starting point, each cylinder will likely have a slightly different sweet spot.  If you're out to 5 turns and not getting improvements, you'll need to change the pilot jets (assuming the carbs are clean internally).
Bminder
Quote from: andyb on April 05, 2014, 09:29:45 AM
As Pat said.
Maybe a little more clarification if you've never worked on carbs before.
Take a screwdriver and gently turn them clockwise until you feel them hit bottom. Stop when you feel that so you don't damage the screws.
Then turn each screw counterclockwise 3 complete turns out and see how it runs.
Billy Minder
92 FJ1200 ABS
mikedastonfj1100
