Brake Lines
Started by Tex, March 30, 2014, 08:26:47 PM
Tex
Ok so after I get my air filter pods and install them I will be going after brake lines. Where can I order a complete kit to do the lines and what would be the average cost?
Thanks,
Scott
Scott
1993 FJ 1200 ABS
There are a few company's that make quality Stainless steel braided brake lines. Cost between the manufacturers varies some.
A few manufacturer's are...
Galfer
Goldridge
Spiegler
Venhill
BTR
Wezmoto
84'-90' models can get a set of front lines for around $100.00 +/- $20.00. For the 91'-93' models, w/no ABS you can use the 89'/90' lines. With ABS the cost can reach the $300.00 range.
Rear lines can be had in the $50.00 range.
I personally have the Goldridge 2 line Race set on my 89' and a Galfer 3 line set on my 87'. Both sets work great, the 2 line set up is easier to bleed.
yamaha fj rider
My advise is to remove the ABS, it's probably not working anyway. Then just order a set of lines of ebay. Different options on line sets pick the ones you like. Hope this helps. Galfer lines are good.
Kurt
93 FJ1200
FJ 09
YZ250X I still love 2 strokes
Tenere 700
FJR1300ES
Tex
Kurt what does removing ABS entail? But I do beleive they are working.
Scott
1993 FJ 1200 ABS
yamaha fj rider
Quote from: Tex on March 31, 2014, 12:39:20 PM
Tex what I did was remove the brake lines and the ABS pump, ABS control unit. Install new stainless lines. If your abs is still working maybe keep it (most quit long ago). I have better breaking without it and the bike is about 25lbs lighter. Here is also a link that shows how to bypass the pump. If I can be any more help just let me know.
http://www.fjowners.com/index.php?action=dlattach;topic=675.0;attach=315
Kurt
93 FJ1200
FJ 09
Tenere 700
FJR1300ES
