Getting closer to completing the wheel swap
Started by Country Joe, March 29, 2014, 10:42:48 PM
Country Joe
 Got the front wheel bearings today(Thanks, Randy!) and installed them in the FZR front wheel. Did a little sanding and polishing on the rim,  called up a buddy that has a NoMar tire changer, went over and had him lever on the ContiMotion.
I'm trying to decide which pair of rotors that I will mount up and run for right now. I have a set that came with the YZF wheel that looks like they have been reground but they are at the low end of the service limit for thickness. Then there is the pair of rotors that is on the bike right now, they have a slight pulse when you brake, but most of the time it is not real noticeable.  The  caliper adaptors to run the 320 mm rotors will have to wait.
I plan on taking the GSXR rear wheel to the powdercoater this week and get the spokes and hub powdercoated black, then finish polishing the rim edges.
Coming together little by little.......
1993 FJ 1200
Country Joe
After measuring all the brake rotors that I have on hand,  and looking in the general maintenance spec files on the forum, I finally realized that the original thickness given in the Haynes manual for a new rotor is in error. All of the rotors that I have are more than .150" thick.  I feel a lot better knowing  that they are not worn as much as they appeared to be. :shok:
1993 FJ 1200
Quote from: Country Joe on March 30, 2014, 11:04:15 PM
I've never heard of that error. You're not confusing metric and imperial measurements are you? The manual I think gives those sort of specs in metric.
Bones
In my book it states : 1984 through 1988
                                Standard................7.5mm (0.295 inch)
                                Minimum................7 mm (0.275 inch)
                                1989 on
                                    Front
                               Standard................4 mm (0.2 inch)
                               Minimum................3.5 mm (0.14 inch )
                                   Rear
                               Standard................7.5 mm (0.295 inch)
                              Disc Runout Limit.....0.15 mm (0.006 inch)
93 fj1200
79 suzuki gt250x7
Country Joe
I just did the calculation, 4mm x .03937 = .1574"
3.5mm x .03947= .1377"
  :pardon:
1993 FJ 1200
