Rear tyre and some other things.
Started by MatYl, March 10, 2014, 09:40:13 AM
Quote from: Arnie on April 22, 2014, 07:54:39 AM
Not trying to hurt your feelings, just trying to correct the information.
We know you're "the authority" :-) on most technical items, but its nice to know that you're human too.
Tell you what..... you be right tomorrow, ok ?
Arnie, you've forgotten. Doug hasn't.
Quote from: MatYl on April 21, 2014, 12:29:35 PM
Same Motox 20-50 oil as allways. But perhaps I try 10-40, thanks for hint. And if it makes no difference, then new spring by you and Arnie's way  :good2:.
Naaa Mate, It was only a thought if the oil type had changed, which I thought could have been the case from your earlier postings. Being same as always means there`s no shortcut, don`t bother trying a different oil, it`s time to proceed with Arnie`s suggestion as next step. Cheers.
Quote from: ribbert on April 22, 2014, 09:51:32 AM
Ahhhh mates, we are sic basteds. I know Noel had more than one "smelling the fray" (sorry I`ve still got Banjo Patterson running around in my head) and I suspect Arnie actually understood...but was taking it to another level. (haven`t checked by pm...)  .....where`s Klavdy when ya need him for a follow through....ummmmm...  :shout: :shout: :shout:  :rofl: :rofl: :rofl:  :drinks: ...bait trail now in place....bloody tweenagers!
MatYl
No more slipping  :good2:. I put two springs, eventually, because I couldn't find new plates just now. But clutch is good in this way. I put new bearing in the pressure plate and result was very hmm... interesting. My FJ's engine has never been so quiet  :good2:. Old one was worn, not so much, but enough to make quite much noise.
