hello of France
Started by fjfrench, January 29, 2014, 05:39:11 PM
Quote from: fjfrench on February 05, 2014, 11:51:38 PM
I looking for a exemple of paints fj for my inspiration.
If you have a connection, i am very interested.
thank you all
A year or so back I spent a lot of time looking at FJ paint schemes. There are a lot of custom paint jobs out there but I couldn't find anything I thought looked good other than the original one. You could change the colours but I reckon Yamaha got the pattern right.
The problem with most of the paint jobs that look good on other bikes is the gap between the upper and lower fairing on the FJ.
The colour's don't need to be original but I reckon the pattern does. This is unless you go for a single colour all over.
I am painting my '92 in early model colours (Black, red and silver)
fjfrench
Hello Noel,
have you a picture of your fj in Blak/red an silver ?
I have a integral fairing.
fjfrench
hello,
I turn to 1200xjr exhaust to put on my fj.
Simply replaced by outputs 18 bits of titanium 38.
Here the origin
Cups disassembled output, clean polish, bored, remove the baffles 18 and replace
new titanium 38
the old chicane
and finish
internal walls are intact, just a little more Big noise but not much stronger
this is the end for this day
good sunday my friend's
fjfrench
the first picture was that the :biggrin:
:crazy:
Wow...nice work there!   :good2:
fjfrench
hello,
and a vacuum gauge homemade
and the final touch
:crazy:
adjusting today trying :good2:
Quote from: fjfrench on March 07, 2014, 01:18:38 AM
hello,
I was wanting to congratulate you on such a fine effort in your own tongue but I discovered all the superlatives I would have chosen in English are of French origin and therefore spelt the same. Anyway, well done!
I have seen another similar tool here recently that I know works very well.
I found the plastic tubing can very quickly collapse on itself and kink at the carby end from engine heat. I slipped these larger pieces of tubing (pictured) over them to prevent this.
Do you have restrictors in line to dampen the fluid response?  They also let you rev the motor without risk of the fluid being sucked into it.
What is the blue tube for?
What are the markings on your garage floor for?
Is that a car engine sitting on the floor and if so what is it from?
fjfrench
Hello,
Excuse me, but I will use the google translator because I have much to say, it will take too much time with the dictionary :yes:
Well, I upgraded the system by a base fluid distribution in copper
I also incorporated with homemade sprinkler heads syringe needles to tranquilize fluids as
it works nickel, carburetors are set
For the red lines on the ground, it's just the edges of the pit for working on cars it is convenient.
Then the engine on the ground at the bottom, it is completely empty, it was the engine of AX 1.4 Diesel 22 years, because with two engine I made one.
here it when finished
fjfrench
Hello everyone,
so here is my FJ FullBlack finished!
fjfrench
oops!
here are the pictures
primer
and final
and voila, there remains only the deco "or"
to a fullblack / or
:bye:
Christian, you've done a very nice job!  The paint looks excellent!
fj johnnie
 That look tres bien!!!
fjfrench
Hello :good2:
with the personnal decals !! :dance2:
and here I am all proud :crazy: :crazy:
and presto! the garage before a bird poops on
watch the sun of northern France!
it feels like Miami :rofl:
You make Black and Gold look good on an FJ... Marsh would be proud to have you with us...
fjfrench
thank you very much  :good2: :hi:
ah yes! if there is one thing I'd like to, it's going to California!
It is a dream ...  :good:
but sorry me: who is Marsh?
