Foot peg bracket (1993)
Started by nurse, August 20, 2013, 09:25:25 AM
nurse
Haven't got mine to hand at the moment as they are being 'restored'
Does anyone happen to know (or could you kindly measure) the outside width of the bracket which holds the footpeg on (via the riveted Clevis pin)?
Reason being I need to order a new Clevis pin. The pin is of the 8mm flavoured variety but don't know the width of the bracket (which will determine length of pin)
Thanks in advance for your help!
hein
The closest pin I found was for a FZ6 part # 91701-08040-00. Use two 8mm id washers, one under the head and one on the bottom, and its a perfect fit. The clevis pin is already drilled so you can use a hitch pin or a cotter pin.
Hein.
nurse
Bless you Hein, you are a good man!
