Top end oiler
Started by Alf, August 18, 2013, 05:45:59 AM
Alf
Travis398
not gonna happen................
Those elbow fittings definitely will not fit in an FJ frame. And the mod is not needed on a bike anyway - they get plenty of oil to the cams when used for the designed purpose -- delivering kookaloo in a motorcycle!
IF for some reason you really wanted to do it - that is not the way!  The oil from that galley is not filtered.
I added a filter in line when I did the dragbike. Using the after market cast big block I had a lot of issues with oil leaks - so I "dry blocked" it. Had to use low profile banjo bolts and had to narrow the banjo fitting slightly. Even then had to grind down a wrench to fit between the frame to tighten it up a hair when it seeped at first.
NOT worth the headache to do on a bike!
Alf
Thanks for your info. I know the mod is not necessary, but the look say: "its tricky" and it is another gadget  :gamer:
