right fork bottom leaking
Started by mtc, April 26, 2020, 08:02:05 PM
The proper alignment starts at the bottom of the forks. The screw/fastener with the pin must have the pin still in place. Some oil will leak out but you can remove the screw and see if the pin portion is still in place. If the pin has been bent or sheared off then time for a new one. With the forks apart, you will see the bottom of the fork internals have a slot. This slot allows the internals to sit with the forks rotated in the proper position over that pin. This is also why you need to hold the fork internals when you tighten the bolt at the bottom. Not holding the fork internals will likely bend or shear off the pin. Do you have a manual to help understand the assembly?
mtc
Quote from: mtc on April 28, 2020, 04:25:30 PM
this one has a word document with lots of pics
http://www.fjowners.com/index.php?topic=1911.0
this one has a word document with lots of pics, so it clearer to me
remove adjuster cap , preload tube, washer and spring
steady bike on  center stand and jack/ shift weight of bike to rear
i don't have to take it all apart, shove the "tool" which i have the 27mm bolt already to hold it, after draining out fluid.
take nut off, replace washer and hex bolt while assuring the rod rod is indexed via a screw or well fitting drift pin to
27 ft lbs
reverse process and
HOPE
it's not what you call a crack somewhere ( which is hard for me to think happened)
Previous Bikes
1979 Yamaha XS1100 best one
1987 FZR600
1987 Fazer
1985 Vision
1982 Seca 750
1978 RD400 Spec II Motor
Live Life Wrong and Perspire
mtc
Quote from: FJmonkey on April 28, 2020, 04:33:50 PM
no manual
Previous Bikes
1987 FZR600
1987 Fazer
1985 Vision
1982 Seca 750
Sparky84
Quote from: mtc on April 28, 2020, 03:08:50 PM
Quote from: RPM - Robert on April 28, 2020, 01:59:16 PM
In order to replace the copper washer the fork must be disassemled as you have to hold the damper rod internally to loosen and tighten it. This 10mm (or 3/8") allen that you used is the bolt that is sealed by the copper washer.
any pictures, it's dark down there and far away to see anything
what is the tool to "hold" this damper is this it?
https://www.rpmracingca.com/proddetail.asp?prod=27mmForkHolder
how long of an extension to get it down there?
do i need a vise? or just the work bench?
why would the washer suddenly leak?if it's a crush washer, can't i just try to tighten it some more?
i don't want  sound like a stupid person,
This is how I was able to hold to undo and tighten, I stood on the unistrut and the unistrut held my T bar
Could also tie the T bar to something long and stand on it.
I can post pages of manual showing fork disassembly, if you need them
Fork was inverted of course.
1979 Kawasaki Z1300
1972 Honda CB750/4 K2
mtc
Quote from: Sparky84 on April 28, 2020, 05:31:12 PM
thank you very much
but i don't want to strip it down that far
just drain the oil and leave the forks on the bike, to just change the leaky washer, everything else on it is fine
if i don't have a helper i could, tie the rachet on top to the frame, just enough to crack the bolt on the bottom,
Previous Bikes
1987 FZR600
1987 Fazer
1985 Vision
1982 Seca 750
RPM - Robert
It will literally take you 5 extra minutes to remove and re install the entire fork leg and make it easier to work on, or at least it should only take you that long.
Advice given. I'll slip back to the campfire and enjoy the popcorn.
(popcorn)
mtc
thanks Mark
Previous Bikes
1987 FZR600
1987 Fazer
1985 Vision
1982 Seca 750
mtc
Quote from: RPM - Robert on April 28, 2020, 06:15:28 PM
(popcorn)
trying to leave the brake caliper and on and not have to clock the fork afterwards
Previous Bikes
1987 FZR600
1987 Fazer
1985 Vision
1982 Seca 750
mtc
Previous Bikes
1987 FZR600
1987 Fazer
1985 Vision
1982 Seca 750
mtc
well i mickey moused a 27mm bolt and was not torque to tight, i looked at the crush washer and it was warped but not crushed at all, i think flipping it the other way would seal it, gone put it back , do a short fill and see if it holds
also
looks like a bit of marring on the bottom of the damper, i think the irregularities and allowing the leak, some yahoo, bounced it on a rough hard surface
copper crush washer, if anyone want to know
20mm os dia.
14mm is dia.
1mm thick
and i have to get a smaller front fender, i took it off and the FJ looks like it lost some weight,( what  a sexy girl!) the old fender was nearly hanging on with all the tabs cracked, bye bye trust me on this one
Previous Bikes
1987 FZR600
1987 Fazer
1985 Vision
1982 Seca 750
mtc
Quote from: mtc on May 02, 2020, 01:46:13 PM
also
20mm os dia.
14mm is dia.
1mm thick
my bad, it's the tube to washer surface that is boogered
Previous Bikes
1987 FZR600
1987 Fazer
1985 Vision
1982 Seca 750
