Ignition switch connector issue
Started by chocker, September 26, 2012, 11:35:04 AM
chocker
Hi,
I am having a problem with the connector to the ignition switch on the wiring harness side. It tends to heat quite a bit and it has already given me problems such as the bike not shutting down and the accessory lights not turning on. I tried to clean the connector and added dielectric grease and it is still giving me problems. The inside of the connector on the harness side seems to be melted a bit and is not looking too good. I was wondering if there is any way to get another connector that the same as the old one or just buy a new connector that is different but still has the three wire connection. I would have to cut the connectore and rewire. Would it cause any problems if I just hardwired it for now to ensure that there's a good connection.
Thanks,
Mark
cut it out if you can't find a new switch block , , sounds like the plug has corroded and is / has gotten hot from too much resistance
yamaha fj rider
Quote from: fj11.5 on September 26, 2012, 03:57:25 PM
+1
Kurt
93 FJ1200
FJ 09
YZ250X I still love 2 strokes
Tenere 700
FJR1300ES
chocker
I cut out the connectors and added an extension to each wire and reconnected directly. I works great. Now I don't have to worry about it overheating or coming loose.
Thanks for the advise,
Mark
This place, Vintage Connections , sells just about everything you need for repairing the wiring to factory-new condition.... I bought their connector kit and a crimper, works GREAT!
