Clutch Problems!
Started by tmfarr2000, May 06, 2012, 11:33:25 AM
tmfarr2000
Hi Folks,
   I have an '86 FJ1200, and I've got a problem. My bike wouldn't start after sitting for about a week.  I checked the fuses, and found the starter fuse blown. I replaced that fuse, and it started right up. HOWEVER, now my clutch is non-existent! It was working fine before the blown fuse. Is there a fuse for the clutch? If so, where is it located? Any help y'all could give me would be GREATLY appreciated!
terryk
Quote from: tmfarr2000 on May 06, 2012, 11:33:25 AM
Hi Folks,
The clutch fuse is located behind the clutch cover wired to friction plate 3.
No, just kidding, I do not believe there is any electrical elements to the clutvh assembly.
Sounds like clutch hydraulic system has a leak. Open the reservior and check the fluid levels. Fill, bleed ( or quick bleed by pulling and releasing handle untill little bubbles stop coming to the surface of the fluid) , check for leaks.
what does non existent mean?
no tension when pulled?
pulls in but does not release?
If the fj sits on its side stand and you have a low fluid level in your master cyl and somebody pulls the clutch it will put air in the system and cause it not to work .
bleed your clutch and go from there.
It might be a good idea to take a quick look at the paint on the sidecase under the slave cyl.   They have a tendency to leak and there will be a fluid trail and possibly bubbling paint if it is leaking.....
