Electrical problem
Started by wills89fj1200, August 16, 2011, 12:50:48 PM
wills89fj1200
I was riding home from work last friday and bike just went dead.  Engine cut off and everything except the clock.  I just put a new battery in the day before.  I'm thinking that it was the cause because it was one size bigger than the one that I had.  Tried jumping it, but nothing.  Bypassed the starter and that worked but still not firing.  Checked fuses but didn't see any burnt out.  I feel that maybe a wire came loose or went bad because halway home the while on the throttle the bike stopped and then went right back to power then stopped and went right back but never cut off. The next time it did the same thing but just cut off.  What or where should i start looking and what possibly caused it?
craigo
Could be the cut off/kill switch on the right handlebar.  Open it up and try some contact cleaner in there.  Happened to me, might be the same problem.
CraigO
CraigO
90FJ1200
ukfj
 Hi I would start by testing the connection to the CDI relay which is found
left side(sitting on bike) behind fairing adjacent  to the flasher relay. You will have
to remove air scoop for access.If all ok work your way through all connector blocks on the
wiring harness.Tedious I know but, it is electrickery. :empathy:
Ride Safe
1989 FJ1200 3CV. 1987 XV535, 1949 SUNBEAM S8.
1949 EXCELSIOR ROADMASTER R1 .
Side stand switch may also be the culprit.
