running problems
Started by eric_court, December 16, 2010, 05:26:42 PM
why my bike only running on 2&3
running problems
2 (100%)
fuel problems
0 (0%)
Total Members Voted: 1
eric_court
hello i have my fj 1200 and it was running ok then it kept blowing it fuese so i replace the cdi now she is only running
on 2&3 i have check my spark replace my regulator replace all the fuses change plug and coils  and replaced the wireing loom and clean the carbs out
i have no i dear so i came to ask you  for your knowlege
roverfj1200
Of your 4 posts this makes the most sense.. But after all the parts you have replaced I would say you need help and the best bet I think is to take the bike to a service centre and have a mechanic  look at it..
Or get a manual and multi meter and start testing.. But a misfire can also be mechanical, like burnt out valves cracked rings, hole in piston.. and the list goes on..
Best I can do without more detailed info.
Cheers.
1988 FJ1200
Richard.
check the wires from the pickup coil (left side of engine )
could maybe be a bad pickup coil.... did not see that amongst the parts listed above.
