Mi Brakes
Started by homerfj1100, March 09, 2016, 04:58:47 PM
homerfj1100
I finally got down to fixing the crap front brakes on my 84/85 FJ11 and the solution gave me a surprise. 2 finger stopping. I've had some blue spots for a few years and could not be bothered with the expense of a front end swap for FJ12 forks. Hassle and you end up throwing away a set of good forks.
So I found some adapters for a VMax. Still, I bought them but was a wuss. Bought a few yards of braided hose. Guessed the banjo fitments. Really. Guessed. And they fitted. With a few problems that I eventually fixed. Not sure how I post pics but will if you wish. Ta. Tony
Homerfj1100
Looking polished and cleaned, 2 finger braking means it performs as well as it looks.
Looks great.... :good2:
krusty
Did you check that the disc contacts all of the pad faces? I did a FJ12 front swap using the 4 pot FJ calipers but retaining the 16" wheel and found that I needed Vmax discs which are about 10mm bigger in diam.
84 FJ1100 x 2
85 FJ1100
89 GL1500
60 Colleda 250TA x 3
63 Suzuki MD50
77 DT125E
77 DT175E
78 DT175F
79 DT250F
It does look like it's only using the outside half of the disc. Looking at the rub marks on the disc.
the fan
I'd like to see a straight on photo. From this angle it does not look like the caliper is properly aligned with the rotor and the pads are not getting full engagement. I may simply be an optical illusion, but it sure looks off in this pic.
Quote from: the fan on March 10, 2016, 11:35:00 AM
[edit] After looking at other pics online, one had the note: "You will also need to fit the 298mm flosting discs as fitted '93-'07, (as the original '85-'92 discs are too small)."
How big are the early FJ rotors?    :pardon:
Good catch. Early FJ vented rotors were 282mm OD
4everFJ
Nice, but the brake lines for the anti-dive should be routed on the inside of the fork legs  :good:
1985 - Yamaha FJ1100 36Y
1978 - Yamaha SR500
1983 - Kawasaki GPZ550 (sold)
1977 - Kawasaki Z400 (sold)
krusty
Quote from: krusty on March 09, 2016, 10:37:44 PM
These are the ones I fitted. They're working great.
http://www.ebay.com.au/itm/2x-Front-Brake-Discs-Rotor-Fits-Yamaha-VMX-12-V-Max-1993-2007-VMX-1200-VMax-XVZ-/291397891981?hash=item43d8aaf78d:g:jVYAAOSwPhdU9r78
84 FJ1100 x 2
85 FJ1100
89 GL1500
63 Suzuki MD50
77 DT125E
77 DT175E
78 DT175F
79 DT250F
CutterBill
If someone will bring me their early FJ, or at least the entire fork/wheel assembly, and some blue dot calipers, I can machine some proper adaptors in my shop.
Bill
Current Stable:
FJ1100
FJ1200 (4)
2015 Super Tenere
2002 Honda Goldwing
Quote from: CutterBill on March 13, 2016, 10:20:42 AM
Bill
I can bring '86 forks and wheel, the Blue dots you will need source on your own. The salvage value of the metal might be worth it...
CutterBill
Quote from: FJmonkey on March 13, 2016, 10:40:50 AM
I can bring '86 forks and wheel, the Blue dots you will need source on your own....
I don't need blue dot calipers for my bike.  At least, I don't think I do.
Guess I should have said... if someone brings me forks and calipers, I can make adaptors for anyone who needs them.
Current Stable:
FJ1100
FJ1200 (4)
2015 Super Tenere
2002 Honda Goldwing
