General Category => Modifications => Topic started by: Sabre093 on June 27, 2013, 05:28:50 PM
Title: Gixxer Rear Sprocket
Post by: Sabre093 on June 27, 2013, 05:28:50 PM
So i'm setting up for the comversion , what combo is everyone running..I'm using 18/38 on my 16's but I hear i'm going to have problems locating a 38 for my 93 Gixxer rim..what's my options out there
Thanks...Big shout out to AviationFred for his help.
Grabbed Bridgestone Battleaxe tires from a demo model less than a 1000 kms on them 120/70017 frt....180/55/17 rear..100$
Title: Re: Gixxer Rear Sprocket
Post by: fj11.5 on June 27, 2013, 05:33:29 PM
I'm using 18/38 on effie the 11.5  :good: with 5.5"  gixxer rear,  found a few on ebay, steel if you can, but I've used An alloy one while using the first wheel swap on the 4.5" rim,  with no problems, ,
Post by: aviationfred on June 27, 2013, 05:47:51 PM
Quote from: Sabre093 on June 27, 2013, 05:28:50 PM
This is the sprocket I am running on mt 92' gsxr750 wheel. should fit on your 93' wheel
http://www.ebay.com/itm/JT-Rear-Sprocket-38T-Suzuki-GSXR750-1990-1992-/321106738641?pt=Motorcycles_Parts_Accessories&hash=item4ac373fdd1#ht_1691wt_1161 (http://www.ebay.com/itm/JT-Rear-Sprocket-38T-Suzuki-GSXR750-1990-1992-/321106738641?pt=Motorcycles_Parts_Accessories&hash=item4ac373fdd1#ht_1691wt_1161)
Post by: craigo on June 27, 2013, 08:32:44 PM
Yep, that's what I'm running on my 90.
CraigO
Post by: Dan Filetti on June 27, 2013, 08:56:24 PM
Quote from: aviationfred on June 27, 2013, 05:47:51 PM
Fred,
That looks like an aluminum sprocket -is it?  If so, be aware that the FJ has eaten many-an-aluminum-sprocket in it's day.  I've seen more than one picture of an aluminum sprocket with NO teeth left, just a semi-smooth outer disk edge.
If not, and it's steel, then let this be a warning to those that consider the aluminum option, eventually conventional wisdom suggests that the FJ will eat it.
Edit, I just took a closer look at the listing, and it did call it out as steel.  Reading IS fundamental....
Post by: X-Ray on July 01, 2013, 09:07:46 AM
Same sprocket I've got. Still have it and the new chain sitting in the drawer to fit sometime.
Post by: Sabre093 on July 10, 2013, 07:37:57 PM
X-Ray...I'm looking for the 2 washers from rear wheel mod...where did ya get them..
Post by: movenon on July 10, 2013, 07:51:44 PM
Quote from: Sabre093 on July 10, 2013, 07:37:57 PM
Pardon, don't mean to but in. The washers I used for my GSXR conversion were off the shelf Ace Hardward washers. Out of memory 20mm or 3/4" diameter washers (I might be wrong there) . As a note in the final adjustment left or right I think I also used one of the washers from the old FJ rear. Depending on the spacers you don't always end up with equal thickness of washers on each side.
Post by: aviationfred on July 10, 2013, 08:01:14 PM
On my 92' GSXR wheel mod. I used the same off the shelf ACE Hardware 20mm ID washer as George says, I used 2. 1 on each side right up against the inboard side of the swingarm.
Post by: X-Ray on July 10, 2013, 08:49:38 PM
You wouldn't believe but I had a heap of these s/steel washers sitting in a btl in the shed. 4mm thickness, 1 each side, and the chain lines up near perfectly. Photos #14 and 15 in my link below show them fitted,
Regards
Ray
Post by: WhiteBeard on July 11, 2013, 12:44:37 AM
I have loads of extra 4mm washers as well, if anybody's interested.
I'm in Sweden, but shipping a couple of washers shouldn't be more than $3.
Nat
Post by: Sabre093 on July 11, 2013, 04:50:46 AM
I will keep looking here so far nothing,I'll hit paydirt somewhere i'm sure...lol
Post by: jamesearthdrum on July 11, 2013, 07:56:26 AM
Quote from: Dan Filetti on June 27, 2013, 08:56:24 PM
Fred,
Been there, done that!  :dash2:
(http://fjowners.com/gallery/3/25_23_04_12_12_27_21.jpeg)
Post by: Arnie on July 11, 2013, 10:37:27 AM
Bet that aluminum sprocket with the nubs (ex teeth) made a hell of a racket every time you gave it some gas.
Post by: eeshed on July 14, 2013, 01:56:57 PM
Thanks for the great information. I'm on a mission to collect all the parts for a gsxr wheel conversion. I will need a 38 teeth sprocket. However, I would like to get a steel, and not aluminum.
I wasn't clear if the link above is for a steel or aluminum. Could you please clarify? If it is aluminum, any suggestions for where I can get a 38 teeth steel sprocket?
Eyal
Post by: movenon on July 14, 2013, 02:45:34 PM
Quote from: eeshed on July 14, 2013, 01:56:57 PM
Eyal
Mine was a 93 GSXR 750 38 tooth JT Rear sprocket off  e bay for 39 bucks.  As a note I flipped my sprocket to end up with a near as I can measure a perfect chain alignment with the front sprocket. Motion Pro makes a 15.00 tool that helps in the chain alignment.
Post by: Sabre093 on July 14, 2013, 02:46:39 PM
JTR816.38... That is part # for steel Sprocket
Post by: aviationfred on July 14, 2013, 02:51:14 PM
Eyal
The eBay link I posted in a previous thread is for a STEEL 38t sprocket.
Here is the link again.
Post by: Sabre093 on July 14, 2013, 02:54:51 PM
I went thru Amazon got same one for 22 and all told 45 to my door..
Post by: X-Ray on July 14, 2013, 06:37:09 PM
I just ordered my JT Steel 38T sprocket from my local Suzuki shop. Only took them 3 days to get in, relatively inexpensive as well,    :drinks:
Post by: eeshed on July 24, 2013, 07:18:52 PM
Just got my 38T sprocket. Just to confirm, I would get a near perfect alignment if I mount the sprocket with the machined indented side on the wheel?
Eyal
