General Category => Modifications => Topic started by: Dizzydevil on May 20, 2009, 08:37:11 PM
Title: turn signal modification or change??
Post by: Dizzydevil on May 20, 2009, 08:37:11 PM
Hey all,
has anyone come across a shorter turn signal or do you have a way to shorten the existing signals.  I can make a custom mount to move the signal backward to fit saddle bags ... but i do not know how to shorten the moose antler signals.  any help would be appreciated.
Title: Re: turn signal modification or change??
Post by: RichBaker on May 21, 2009, 07:21:59 PM
 I completely removed the stalk and used a 1/4" compression fitting in its place.... don't recall exactly what I did, but someone on the Yahoo group posted it all originally. Maybe he's around here..... it's been a few years. I do remember having to drill the center ridge out of the fitting.
Post by: Dizzydevil on May 21, 2009, 10:00:22 PM
thks for the tip ... will definitely look into it ....
:good:
Post by: RichBaker on May 22, 2009, 08:13:28 PM
 Thought about it some and as I recall, the compression fitting replaces the stalk. There's a nut inside the light housing, remove the socket and you can get to it. Use the comp nut to hold the fitting in the housing and reassemble...... it's pretty obvious how it all goes back together.  You have to drill the ridge out of the fitting so the wires will fit thru.
Post by: rlucas on May 23, 2009, 10:58:30 AM
Might have been me. You can remove the rubber boots and shorten the stalk using basic brass plumbing fittings. Dunno if it's enough clearance for bags, but it's a lot neater. I don't recall the exact details, but it's fairly obvious if you eyeball it. Just a threaded double-end brass coupler from Ace Hardware. I don't recall having to drill out the coupler...I think I fed the wires through and re-crimped the connectors.
The coupler's got threads on both ends and a hex in the middle. Takes about an inch-and-a-half off each side. You'll need a nut on the bracket side; you can actually thread the signal right onto the adapter. Five years...no problems.
Rossi
Post by: Dizzydevil on May 23, 2009, 08:19:16 PM
perfect thks guys ...
did the modification today ... worked like a charm ... the stalk is completely gone ... now working on a bracket to move the lights backwards.  will let you know how it goes and i will post some pics.
cheers Steve
Post by: RichBaker on May 25, 2009, 06:27:29 PM
Yep, it was you..... I seem to remember drilling it out, but I didn't cut the wire ends off...
Glad it worked for you, Steve.
Hope everyone is having a great Memorial Day!
Cheers, Rich
Post by: Dizzydevil on May 29, 2009, 09:42:18 PM
thks again everyone looks great ... still working on a bracket to move the lights back a fair bit will get some pics up real soon
Post by: ozzstar on June 08, 2009, 07:01:16 PM
Quote from: Dizzydevil on May 23, 2009, 08:19:16 PM
cheers Steve
Do you have any pictures of what it looks like now?  I would really like to see it.
Thanks, here is my email address.
ozzstar@aol.com
Post by: higbonzo on August 01, 2009, 07:05:55 PM
Quote from: Dizzydevil on May 20, 2009, 08:37:11 PM
Hey all,
Steve,
How does this look?
(http://inlinethumb02.webshots.com/43649/2422853620045553760S600x600Q85.jpg)
Post by: simi_ed on August 01, 2009, 09:59:17 PM
I  have Yamaha brackets that relocate the signals backwards.  They're only small metal brackets about 0.125 "/3mm thick.  About 1" wide x 2.5 ", bent 90 degrees in the center.  I can post a picture, but they're REALLY simple.
BTW, nice job on the short stalks!  I may try that too!
