turn signal modification or change??
Started by Dizzydevil, May 20, 2009, 08:37:11 PM
Dizzydevil
Hey all,
has anyone come across a shorter turn signal or do you have a way to shorten the existing signals.  I can make a custom mount to move the signal backward to fit saddle bags ... but i do not know how to shorten the moose antler signals.  any help would be appreciated.
RichBaker
 I completely removed the stalk and used a 1/4" compression fitting in its place.... don't recall exactly what I did, but someone on the Yahoo group posted it all originally. Maybe he's around here..... it's been a few years. I do remember having to drill the center ridge out of the fitting.
Tennessee Squire
90 FJ1200, 03 WR450F ;8^P
Dizzydevil
thks for the tip ... will definitely look into it ....
:good:
RichBaker
 Thought about it some and as I recall, the compression fitting replaces the stalk. There's a nut inside the light housing, remove the socket and you can get to it. Use the comp nut to hold the fitting in the housing and reassemble...... it's pretty obvious how it all goes back together.  You have to drill the ridge out of the fitting so the wires will fit thru.
Tennessee Squire
rlucas
Might have been me. You can remove the rubber boots and shorten the stalk using basic brass plumbing fittings. Dunno if it's enough clearance for bags, but it's a lot neater. I don't recall the exact details, but it's fairly obvious if you eyeball it. Just a threaded double-end brass coupler from Ace Hardware. I don't recall having to drill out the coupler...I think I fed the wires through and re-crimped the connectors.
The coupler's got threads on both ends and a hex in the middle. Takes about an inch-and-a-half off each side. You'll need a nut on the bracket side; you can actually thread the signal right onto the adapter. Five years...no problems.
Rossi
Dizzydevil
perfect thks guys ...
did the modification today ... worked like a charm ... the stalk is completely gone ... now working on a bracket to move the lights backwards.  will let you know how it goes and i will post some pics.
cheers Steve
RichBaker
Yep, it was you..... I seem to remember drilling it out, but I didn't cut the wire ends off...
Glad it worked for you, Steve.
Hope everyone is having a great Memorial Day!
Cheers, Rich
Tennessee Squire
Dizzydevil
thks again everyone looks great ... still working on a bracket to move the lights back a fair bit will get some pics up real soon
ozzstar
Quote from: Dizzydevil on May 23, 2009, 08:19:16 PM
cheers Steve
Do you have any pictures of what it looks like now?  I would really like to see it.
Thanks, here is my email address.
ozzstar@aol.com
1986 FJ1200
Delaware
higbonzo
Quote from: Dizzydevil on May 20, 2009, 08:37:11 PM
Hey all,
Steve,
How does this look?
I  have Yamaha brackets that relocate the signals backwards.  They're only small metal brackets about 0.125 "/3mm thick.  About 1" wide x 2.5 ", bent 90 degrees in the center.  I can post a picture, but they're REALLY simple.
BTW, nice job on the short stalks!  I may try that too!
