so me and my friend bought a 92 yamaha seca 2 for 100 dolalars, i mean what a deal.
it cranks but there is sometype of fuel issue.
well when taking a look at the bike we noticed there was fuel leaking out of one of the exhaust pipes.....
i know this isnt a good thing and have an idea of what is wrong but can anyone else give me some advice on this? thanks
Quote from: irishluck on April 11, 2011, 09:46:48 AM
thanks for the links buttt i actually work for a motorcycle shop i can get my parts alot cheaper than that=D.....
What does your shop say? I suspect it's a float needle stuck open in the carb.
(popcorn)
(popcorn) (popcorn)
That was funny Pat! :good2:
Quote from: irishluck on April 13, 2011, 12:35:55 AM
How bout sell it for $200 and make a good profit from it? :biggrin:
Quote from: Scooterbob on April 13, 2011, 11:15:20 AM
drain the fuel tank and the leak will stop.
Throw cheap parts at it.
As we say in french;
"Et vlan dans les dents!!!!"
Alain
Fuel leaking unburnt out the exhaust? When running, means that there's no spark on that cylinder. When sitting, means that the carb is leaking and you'll probably destroy expensive stuff when you start it up and that the oil is contaminated.
Part it out, make $400 profit, and buy something nicer. Or buy a few more at that price and part those out.
Profit!
or fix it and gain experience. :good2:
Fit it. Learn something. Clean the carbs, just like a FJ. Those little 600's are fun bikes.
When floats stick on down draft carbs, fuel coming out the exhaust pipe is common.
ya i talked to the guys here were i work after i posted this and they told me that its the carbs, either stuck float, needle, hole in diaphram, something. I tore it apart and its very gunky and the needle it like gunked shut. So all it needs is a good cleaning and ill have it fixed, and i cant sell it, not mine, lent friend 100 dollars tell tomorrow for the bike. just fixing it for him.
nice ! geez your a good fella! and congrats on fixing it.:D knowledge is nothing without experience and vice versa
got another issue with this bike, Like I said, I know this isn't an fj bike but its still Yamaha=D
we got it to crank, fixed the carbs and such, but now there is absolutely no spark, we checked the plugs and wires and everything is connected securely. In my experience its kinda rare for both coils to go out at the same time but I do understand it can happen with a short or something.
does anyone maybe know why we aren't getting spark? Honestly i think its the ignitor....
(popcorn) (popcorn) (popcorn) (popcorn)
Kickstand switch, clutch switch, killswitch. Probably something stupid. Check for power at appropriate places.
I know we have checked the kill switch. That one is working fine. Can the kickstand switch and the clutch switch or something really cause it to have no spark at all? I never did think about that, i mean i know the kick stand switch when put it gear and is down that it will die when giving gas and letting off clutch.
How else would they work?
KS and Clutch sw both kill power to the ignition..........
anyway to bypass to see if those sensors bad?
Yea, start at the sensor and follow the wires back to the closest connector. Unplug the connector.
You now have 2 plugs, one plug and wires goes to the sensor... and the other plug and wires goes to the ignition.
With me so far? Follow this carefully....
On the plug that goes to the ignition, there are 2 prongs in that plug, one for each wire, bridge or tie those 2 prongs together with a piece of wire.
Follow this carefully, or a loud popping noise will come out of the engine.
Quote from: Pat Conlon on May 19, 2011, 05:47:41 PM
We need a Smiley for this, plugging his ears with his fingers, waiting for "Kaboom".....
haha
al-right ill give that a try tonight then. I haven't had time to do anything all week been working to much but ill give it a go tonight
i bypassed both sensors, no spark still, so ignitor?
or should i check something else
I'd clean the carbs again...
carbs are spotless, new jets, needles, everything.
but what would that have to do woith having no spark?
Absolutely NOTHING.
so i turned the bike on. Just in the on position. And checked the output power of the ignitor, its only getting 6v, shouldn't that be getting 12v?
