General Category => Modifications => Topic started by: ArcticFJ1200A on July 20, 2017, 05:23:45 AM
Title: Steering stem nut
Post by: ArcticFJ1200A on July 20, 2017, 05:23:45 AM
Does anyone of you know if the steering stem nut is one piece only or if it consist of separate cap and nut? Need the cap off to install a fork stem yoke 1" Ball Mount for my navigation unit.
Title: Re: Steering stem nut
Post by: FJ1100mjk on July 20, 2017, 06:43:56 AM
It's one piece.
Post by: ArcticFJ1200A on July 24, 2017, 09:33:09 AM
Quote from: FJ1100mjk on July 20, 2017, 06:43:56 AM
It's one piece.
Thanks. I'll put in my lathe then, to remove the cap the hard way :)
Post by: giantkiller on July 24, 2017, 01:26:55 PM
I just drilled a hole through the center of the cap. Put the bolt for the RAM mount through the hole with the nut up inside the cap. Tightened it down. And epoxied the nut up inside the cap. I put a little oil on the the threads on the bolt just in case. Been in use for years.
