Saw this product discussed on another riders group. Never used it, just throwing it out there.
Add it to your chemical arsenal.
http://www.nikwax-usa.com/en-us/products/productdetail.php?productid=274&itemid=-1&fabricid=-1 (http://www.nikwax-usa.com/en-us/products/productdetail.php?productid=274&itemid=-1&fabricid=-1)
http://www.revzilla.com/product/nikwax-visor-proof (http://www.revzilla.com/product/nikwax-visor-proof)
Nu Finish car polish will do as good as any of the wax products.. :good2:
Not sure if we get that brand in Australia,
I have been using RainX for a few years now, Amazing stuff! When used on the helmet visor the water beads off clean, no wiping with the glove anymore. I use it on the cars too.
(http://fjowners.com/gallery/9/1121_03_11_15_5_55_23.png)
Quote from: mr blackstock on November 03, 2015, 05:56:54 AM
Yes, have used Rain X, and car wax too. I have read that plastic doesn't always agree with Rain X on it, but when I have used it, I experienced no ill effects. Though I only used it a handful of times, and not always on the same motorcycle. I have read too, that supposedly, there's a plastic-friendly version of it.
I also saw that Pledge, a furniture wax of all things, will work too.
Like I said above, I'm just throwing the Nikwax thing out there, because it's something new. At least I hadn't seen it before, and I may give it a try.
RainX doesn't like Lexan. Beware, it will cloud it up. Buddy found out the hard way on his softail.
I've got a bottle of the Nikwax. Got it from the bike gear shop that use to be in Telico.
Works good.
Are visors made of lexan?
I've got a transitions shield on my Bell helmets and I'm always worried that it will get messed up using chemical's. Don't know if the transitions is a Coating. Or if it's built in to the plastic?
Quote from: giantkiller on November 04, 2015, 11:57:49 AM
Works good.
Dan, knowing your magnetism towards the dawn dwelling four legged fur covered bags of meat you encounter, this video might help you choose the proper see-through protective plastic you use as both a windscreen and visor.
http://www.coloradoplastics.com/blog-0/bid/42625/Polycarbonate-Lexan-vs-Acrylic-Lucite (http://www.coloradoplastics.com/blog-0/bid/42625/Polycarbonate-Lexan-vs-Acrylic-Lucite)
And the transition effect is formulated into the material, not a coating.
You can always use a test area on your visor off to the side. We never see that far over with the helmet on. Unless you can see like a chameleon.
(https://encrypted-tbn0.gstatic.com/images?q=tbn:ANd9GcTO7SFHe3sMV0cQOy7-ItS9iWY4TCSdvhvX6GakjT4x7x-b-FTk)
Yah the last thing I slammed my body into was the dirt. Probably around 60ish mph. Was topped out with the raptor, before hitting the brakes briefly.
But thanks Mark. I figured it was part of the plastic but wasn't sure.
69 degree's out going for a spin on the 89. Probably the last nice day.
I generally use Pledge as a cheap alternative to Plexus or the Honda cleaner. I've alternate with the Amsoil spray cleaner. But I've found the wax-like properties of Pledge on my visor improves the water shedding by a good bit. FYI.
