General Category => Maintenance => Topic started by: wirehairs on April 02, 2015, 07:59:18 PM
Title: Chain guard removal question... And yes, I'm embarrassed....
Post by: wirehairs on April 02, 2015, 07:59:18 PM
How strange to see a screw tucked up against the muffler that's holding on the rear of the chain guard.  But OK.  I bought a 90 degree screwdriver to remove it.  But then that front one... really?  So it's embarrassing to ask, but is the only way to remove that front screw is to use a stubby phillips screwdriver blindly in there?  I mean, you can't see the screw so you are doing it blindly, and it's so tight in there, it's hard to get leverage on the screwdriver.  I don't know - I just have a hard time believing that Yamaha didn't design this differently.
I almost thought removing the battery box was needed, that's even crazier...
Title: Re: Chain guard removal question... And yes, I'm embarrassed....
Post by: FJmonkey on April 02, 2015, 08:39:58 PM
Quote from: wirehairs on April 02, 2015, 07:59:18 PM
Getting to it requires removing two screws that hold the front half of the rear fender. Access them from inside the rear fender area, 10MM hex head I think. The fender pops right out, then you have all kinds of room to work.
(http://fjowners.com/gallery/8/104_02_04_15_7_36_06.jpeg)
Time with Randy has all kinds of perks....
Post by: wirehairs on April 02, 2015, 09:00:47 PM
[/quote]
[/quote]
Ahhh....haha.  I'll try that tomorrow then; too late now.  But thanks a million!  Would of been nice for the manual to tell me that....
Post by: FJmonkey on April 02, 2015, 09:05:52 PM
Quote from: wirehairs on April 02, 2015, 09:00:47 PM
Post up tomorrow then mate...
Post by: ken65 on April 02, 2015, 09:23:59 PM
I tried to get mine off once aswell, thanks for the tip Mr Monkey..
Post by: FJmonkey on April 02, 2015, 09:28:06 PM
Quote from: ken65 on April 02, 2015, 09:23:59 PM
I tried to get mine off once as well, thanks for the tip Mr Monkey..
I had a teacher...
Post by: aviationfred on April 02, 2015, 10:07:04 PM
I went the other way than a stubby screwdriver. I pulled the seat and used a Phillips screwdriver that has an 18" blade.
Post by: ribbert on April 02, 2015, 10:37:05 PM
Quote from: aviationfred on April 02, 2015, 10:07:04 PM
I've always just used a right angle PH.
Post by: movenon on April 02, 2015, 10:42:30 PM
Last time I was in the area I replaced the JIS screw with a bolt.
Post by: wirehairs on April 03, 2015, 12:12:28 PM
Quote from: movenon on April 02, 2015, 10:42:30 PM
I agree that's the best solution.
Post by: wirehairs on April 03, 2015, 12:16:11 PM
Great idea, but on the 93, there's no sight line through the plastic and junk that's above it.   :sorry:
Post by: FJmonkey on April 03, 2015, 12:18:25 PM
Quote from: wirehairs on April 03, 2015, 12:16:11 PM
Bugger! Is it least easier to get at with the fender out of the way?
Post by: Pat Conlon on April 03, 2015, 01:54:42 PM
With abs it's easier to pull the swing arm... good time to service the linkage and pivot bearings.
Post by: Timmer on January 29, 2017, 06:42:13 PM
Hey, Thanks for that! I dicked around with it for 30 minutes and then realized that someone else had had to deal with this.  Thanks again!
Post by: balky1 on January 30, 2017, 01:51:14 AM
I just used the pliers to unscrew it and screw it back in.  :rofl:
