General Category => Maintenance => Topic started by: glukasil on July 15, 2014, 11:33:35 PM
Title: 96 fj1200 cyls order?
Post by: glukasil on July 15, 2014, 11:33:35 PM
hi guys. i have the bike and my spark plug leads are disconnected from the plugs. there are numbers on the leads but no numbers on cyls....Could you help me.  Thanks a lot
Title: Re: 96 fj1200 cyls order?
Post by: movenon on July 15, 2014, 11:50:49 PM
OK I will try. Facing forward like you are sitting on the bike read from left to right 1 2 3 4 attach the wires in that order. That's not the firing seq but it is the way those wires go back on.  Let us know how she runs.
Post by: Pat Conlon on July 16, 2014, 01:09:53 AM
Just to double check to make sure the numbers on the wires are correct, after you are done you should have:
(as you sit on the bike) the 2 plug wires from the left coil are for cylinders #1 and #4..... the 2 plug wires from the right coil go to #2 and #3
Post by: glukasil on July 16, 2014, 06:07:14 AM
Thanks guys a lot... i think my leads marked from right to left.....if i put them in from left to right, each coil has both leads crossed.....it does not seem right....does it?
Post by: ribbert on July 16, 2014, 06:16:02 AM
Quote from: glukasil on July 16, 2014, 06:07:14 AM
Don't worry about them crossing over each other. Put them on as suggested, left to right.
Post by: Pat Conlon on July 16, 2014, 12:27:18 PM
Quote from: Pat Conlon on July 16, 2014, 01:09:53 AM
You can uncross them as long as the left coil sparks #1 and 4....and the right coil sparks #2 and 3.....
...unless someone switched the coil signal leads on you...unlikely but you never know...to check this, in your Owners Handbook...in the back there is a wring diagram for the model of your bike....look at the color wires going to the right/left coils on your bike and then compare it to your wiring diagram...they should match.
Post by: glukasil on July 16, 2014, 05:19:38 PM
Thanks guys. Will try it today. Still sorting out electric loom.
Post by: Pat Conlon on July 16, 2014, 05:39:49 PM
Get the right color coil signal wires to the correct left and right coil.....or all bets are off.....
Post by: glukasil on July 16, 2014, 06:15:30 PM
Thanx mate. You are a wiki of fh1200
Post by: EnrAgeD on March 09, 2015, 02:48:06 PM
