General Category => Maintenance => Topic started by: Joe Sull on April 16, 2014, 02:39:51 PM
Title: External fuel blatter
Post by: Joe Sull on April 16, 2014, 02:39:51 PM
Any of you guys rig there own blatter for running the engine without the tank on it.
Title: Re: External fuel blatter
Post by: Pat Conlon on April 16, 2014, 03:59:52 PM
Yes. Folks who have the gravity fed '84-'87s need one....folks who have the fuel pump models with the longer hose, can simply reverse their tanks and rest the tank on the subframe.
I used a old lawn mower tank hung with a coat hanger for many years, until my son bought me a Motion Pro tank for Xmas....either works just fine.
Post by: Joe Sull on April 16, 2014, 04:41:59 PM
Ah huh Thats a good idea. I can use the little tank off my outboard. Did you use a reducer to go from hose to hose?
Post by: FJmonkey on April 16, 2014, 06:07:08 PM
I use an old 1 liter water bottle. Drilled a hole in the cap small enough that the 10 MM fuel line wedges in and seals, inverted it and added wire to hang it by. Drilled another small hole the top (was originally the bottom) so I can fill it. Added a stopcock to control fuel flow. 1/2 a liter is plenty of fuel for syncing the carbs.
Post by: Pat Conlon on April 16, 2014, 07:21:02 PM
Quote from: Joe Sull on April 16, 2014, 04:41:59 PM
Nope, the small hose off the Motion Pro fits inside the large Yamaha hose feeding the carbs....
Post by: Firehawk068 on April 16, 2014, 07:49:18 PM
I use a small (cheap) universal radiator overflow tank, purchased at Autozone for around $7-$8
The clear hose came with it, and came with a hanger bracket......................
(http://i859.photobucket.com/albums/ab154/firehawk068/CIMG4512.jpg) (http://s859.photobucket.com/user/firehawk068/media/CIMG4512.jpg.html)
(http://i859.photobucket.com/albums/ab154/firehawk068/4_zps4b7fccd0.jpg) (http://s859.photobucket.com/user/firehawk068/media/4_zps4b7fccd0.jpg.html)
Post by: yamaha fj rider on April 16, 2014, 11:44:19 PM
Nice Alan, looks good. I will be getting one of those.
Kurt
Post by: Joe Sull on April 17, 2014, 06:28:58 AM
Bunch of good ideas. I had one of those overflow bottles for 3 or 4 years and thought I'd have a use for it then thru it out last summer. :unknown:
Quote from: FJmonkey on April 16, 2014, 06:07:08 PM
I had a 3/8" threaded air barb that I tried to thread into a plastic jug and make a funnel. It leaked and was very awkward. Like juggling kittens as I worked. Maybe just forcing the rubber tube in to the bottle would work much better.
Post by: movenon on April 17, 2014, 09:35:54 AM
I like Allan's.  I had been thinking about buying a used mini bike or small dirt bike tank and using that because it would probably have a shut off valve already on.
e bay or motorcycle wrecker item.
