Rear shock
Started by fuel80guy, July 24, 2013, 06:06:36 PM
fuel80guy
First off if I had the coin I'd buy a rpm shock.
Is there any other shocks that are compatible with my 85 fj1100.
I don't want to do a bunch of modifications just swap out my stock shock.
Quote from: fuel80guy on July 24, 2013, 06:06:36 PM
Unfortunately, unless you convert over the the later model swing arm & linkage there is nothing that will work on the early model FJ1100/1200
The lower pivot system on the early model FJ's is the difference that will not allow you to use any of the other wrecking yard shocks from other bikes.
fuel80guy
So I'm guessing stock shocks aren't rebuildable?
oldktmdude
Quote from: fuel80guy on July 24, 2013, 06:29:14 PM
I wouldn't waste my money rebuilding a shock that wasn't even up to the job when they were new.
1985 FJ1100 x2 (1 sold)
2009 TDM 900
1979 Kawasaki Z650 (sold)
2001 KTM 520 exc (sold)
2004 GasGas Ec300
1981 Honda CB 900 F (sold)
RichBaker
Not designed to be rebuilt, there are some guys that used to do it, Lindemans might have been one.  Not that it would be worth it, though....The stock shock was crap.
Tennessee Squire
90 FJ1200, 03 WR450F ;8^P
yamaha fj rider
93 FJ1200
FJ 09
YZ250X I still love 2 strokes
Tenere 700
FJR1300ES
WR250F
Quote from: yamaha fj rider on July 24, 2013, 07:27:19 PM
Honda F4I...
Kurt
Sorry, I stand corrected.
I thought they were only used on the later model bikes with the yoke lower mounting, but I forgot that those had to be welded upon to fit.
yamaha fj rider
Quote from: racerrad8 on July 24, 2013, 07:42:31 PM
Honda F4I...
Kurt
Mark this day on the calendar. Randy made a mistake, the stars must be ought of alignment.  :lol:
Kurt
93 FJ1200
FJ 09
Tenere 700
FJR1300ES
WR250F
fj11.5
F4i shock fits with very little work, a few others have done it since I fitted one to my 84 ,
Rod
84 Fj1100  effie , with mods
They are under spung. But still a lot better than stock. You can get a heavier spring from eibach for about $69. The honda guys generally think 950lb spring is as big as you want to go with stock valves.
Oh yah stock spring on the honda shock is 780lb.
fj11.5
Does rider weight effect the standard honda spring , I've had no issues with the shock as is, ,but I do only weîgh 70 kg :biggrin:
fintip
The shock page (still needs work, but a good starting point)
http://fjowners.wikidot.com/rear-shock
-ZAMM
IBA:54952
Quote from: fj11.5 on July 25, 2013, 01:38:58 AM
yah I'm about 280 lbs.
fj11.5
Could be why the shock is fine with me  :scratch_one-s_head:
