Bad ignition switch
Started by 1Shito-ryu, July 19, 2013, 09:18:30 AM
1Shito-ryu
I found the problem last night on my fj.  I previously posted that i was riding and my bike cut off completly.  I had no lights, horn or anything.  Last night I found a corroded wire.  I fixed the wire but still had no power.  Then I traced the short to the ignition switch.  On RPM'S website he has two different of ignition switches.  Will the flat key just hook up without having to change the connector?   Thanks for all yall's help.
I'll check once the sun comes up  :biggrin:,, but fairly certain they plug in and away you go,, as I bought a round key one ,but was awhile ago
I just bought a flat key switch for my '84 from RPM. It was plug and play.
