Electrical problem either battery, regulator or starter.
Started by Oman75, July 18, 2013, 06:59:40 PM
Oman75
My 1989 FJ has a new problem. I ran the bike hard in the Arizona heat. I left Payson AZ and went to Tonto Basin the temperature was running about 105 degrees the distance was about fifty miles. I arrived and parked the bike and opened the doors garage shed and went to the bike and refired. I pulled away and my neighbor said something to me and I killed the engine so I could hear him. I refired again and the starter went "RRRR" "RRR" twice and fired I parked the FJ in its shelter and cut the engine. I got off the bike and tried to fire it up again. Not a peep from the starter and the head lamp went off and yet the fuel pump was running. I checked the battery voltage, which was about 13 volts. Left and went to get some food and when I came back I fired the bike up and all was normal. I checked the regulator output, well within specifications. I am planning a long trip up North and I do not want any problem to arise. I think the armature in the starter is swelling due to heat. Any other suggestions?
Oman 75 will check for new post.
Thanks
David Sanders motto is: Enjoy the day!
Its a comon problem whith fj starter motors, they struggle with the heat , a good clean should sort it out, or even a rebuild kit from rpm ,, my 88 had a 2 brush starter fitted by a po ,struggled badly when hot , swapped it for an xjr 4 brush unit
Thmsdoyle
My 84 had three starters by po in 6 months. With the last one shattering the magnets, all we're two brush. I went through all wiring connections, plugs, took starter switch apart which I found was sticking. Long story cut short, new starter was a four brush from RPM. Fires up with no issues, this starter is a year hold with I'm sure a few hundred starts. Check everything out, if you decide to replace go with a four brush starter. You won't regret it.
Tommy D.
