Front Sprocket Bolt Size
Started by Brad, June 28, 2013, 05:48:56 PM
Brad
Does anyone know off the top of their head what the size is?
Faster than a speeding ticket!
Brad
Awesome! Thank you very much!  :hi:
Quote from: Brad on June 28, 2013, 05:48:56 PM
36mm
Brad
fj11.5
You didn't know what size nuts you had monkey :shok: :lol:
84 Fj1100  effie , with mods
Brad
36MM...shoot..now I know how I could have measured that.  :rofl2:
Quote from: fj11.5 on July 02, 2013, 05:35:34 PM
Naw.. I was shocked that the nut size was way too small... Now I know why the FJ fuel tank is missing the manly clearance that Corbin  made a killing on with the Kookaloo hump.....
Charlie-brm
While we are at the front sprocket, I gave up trying to remove the cover for fear of cracking it while doing some gentle test prying from the bottom. The amount of movement was barely noticeable after a few minutes of wiggling a pry under there. What's the correct way to get the cover off?
1979 XS750SF - 2005 to 2012
Brad
Quote from: Charlie-brm on July 12, 2013, 12:34:23 PM
Just to double check, you did take off the clutch slave and shifter, right?
There are a total of 6 bolts that you need to take out. 3 for the clutch slave, and 3 for the cover, and the shifter.
I have my bike here at work if you would like pictures..I can do a step by step if that would help. :)
