Flame thrower
Started by moonrunnah, June 28, 2013, 05:14:06 PM
moonrunnah
My exhuast throws flames at around 1500 rpm and at red line and sometimes well holding a steady rpm. Any help??? Burnt valves????
Tryed posting this morning but doesn't look like it went through
When in doubt throttle out
Quote from: moonrunnah on June 28, 2013, 05:14:06 PM
I would start with wanting to know how much compression I had. What do your plugs look like ? Have you checked ?
More information, ? Have you preformed any maintenance on your bike lately ? Other than the flames is it miss firing ? Smell fuel ? Exhaust smoking ?
Hard to digitally trouble shoot with out more information.
moonrunnah
Doesn't smell like gas last I did was replace the petcock and jet the carbs I haven't checked plugs yet ( haven't ran it much since I did the jets) I don't know what the compression is as I don't have a tester
Quote from: moonrunnah on June 28, 2013, 06:41:56 PM
Rejet the carbs? Did you need to rejet? What jets did you change from/to and why?
Quote from: FJmonkey on June 28, 2013, 06:44:32 PM
Event time line.. Did your problem start right after you worked on the carbs ?
moonrunnah
Uni pods and 4-1 d&d exhaust so I went up 10 percent to 125s for mains
It got worse it did it a redline when I would shift now it does it quite often probably from the bigger jets
Quote from: moonrunnah on June 28, 2013, 06:50:57 PM
If it started after you did the mods then my best guess, you messed something up in the carbs more than just the jetting.
Did you do a plug reading ?  Still recommend you do a compression check.
I switched to SupperTrapp slip-ons and UNI pods. I rejetted to #40 pilots and 112.5 mains, needles shimmed up, clip moved down one groove. I might be a tad lean but not far from a good setting. 125 might a tad much, not sure about 4/1 systems. What jets are you using? Differnet brands have differnet standard sizes.
oldktmdude
125's are probably about two sizes too big in my opinion. I've got similar mods to you and 117.5's seem about right. Also check that your header gaskets are sealing properly.
1985 FJ1100 x2 (1 sold)
2009 TDM 900
1979 Kawasaki Z650 (sold)
2001 KTM 520 exc (sold)
2004 GasGas Ec300
1981 Honda CB 900 F (sold)
moonrunnah
The stock I believe are 125s and I was told ten percent but I will do test and go through my carbs again tomorrow thanks for the help
moonrunnah
Quote from: moonrunnah on June 28, 2013, 08:04:56 PM
I ment 112.5 for stock according to my factory manuel
Quote from: moonrunnah on June 28, 2013, 08:13:29 PM
I will need to check what I have then next time I pull the carbs... If they are 112.5 then it may be why I think I am a little rich. I will check the plugs first though...
Quote from: FJmonkey on June 28, 2013, 08:39:57 PM
Mine are 112.5. The 1990 stock jets were leaned down to 110. I just kicked it up a little because the new laced gas that we are running seems to be technically lean and most FJ's like a bit more fuel.  My needle position is down on the 4th grove from the top. Runs fine at 2950 feet elevation.
POST A VIDEO!   Bet it makes tailgaters back off!
moonrunnah
Quote from: fj1289 on June 29, 2013, 01:15:26 PM
Haha yea it does ill try to get a video this week but no promises
