Bolt dimensions
Started by WhiteBeard, June 24, 2013, 01:41:31 PM
WhiteBeard
Does somebody here know the dimensions of bolt no. 28 below?
The PO changed these into low grade bolts...  :negative:
Too easily stripped... don't ask me how I know.
Is the correct bolt dimension 5.0 mm in diameter and 50 mm length?
Thanks once again,
Nat
Ill get back to you,  unless someone else gets here first
Part number is:  95811-06045-00
Which means the bolt is an M6 x 45mm length
Hooligan
Quote from: fj11.5 on June 24, 2013, 05:18:47 PM
shaft length 44.8mm.    thread width 5.8mm.     shoulder width 5.1.  Shoulder length 23.9mm.  10mm hex head.  10mm nut
WhiteBeard
Wow, thanks. You guys are the best.
And I will learn how to read those part numbers.
THANK YOU!
Nat
No worries mate, ill go put this bolt back in the spare arm now  :biggrin:
Tiger
 :hi: Metric hex head cap screws (bolts) come in two basic grades: 8.8 and 10.9...8.8 is the lesser grade at 116,000 psi tensile strength and 10.9 a higher grade at 150,000 psi tensile strength...different manufacturers will differ to some degree... :good: Guess what, among other things, I sell for a living :lol: :rofl: :rofl2:... :biggrin:
John.
This little bolt had a cute number 8 stamped on the top  :biggrin:
