Greetings from Columbus, WI! (USA)
Started by iMav, June 23, 2013, 06:23:47 PM
iMav
Quote from: jscgdunn on June 25, 2013, 02:32:09 PM
You will find that for the stock wheel tire selection is limited.  There are only one or two (Avon, Michelin) supplying radials and you are also limited to the 150 width.
Ok.  The previous owner just recently spooned on new rubber...so I'll wait till I need a new rear tire to look at changing the wheel out.
jscgdunn
Yep burn it off first!  Will give you time to look at the all the options.
Jeff
90 FJ 1200 (Son # 2), Stock
iMav
Are there any aftermarket mirrors that are direct bolt on replacements?  My right one has a slight cosmetic issue and is a bit loose at the mirror.
Yes, there are many after market mirrors that are a direct bolt on replacement.
Quote from: iMav on June 25, 2013, 03:03:26 PM
Here is an inexpensive set of mirrors that will work.
http://www.zillion8.com/motorcycle-mirror/honda-motorcycle-mirror/carbon-fiber-honda-cbr1000rr-mirror-2005-2006?gclid=CIPxvom6gLgCFdFDMgodYVMASw
