Need to drill holes in new Fiberglass Chin Fairing!!!!
Started by poker007, June 01, 2013, 06:44:35 PM
poker007
I was wondering if there is a certain way to go about drilling the holes in my lower chin fairing? It is all fiberglass: and i would die if i screwed it up....!I picked up some rubber washers today at hardware store, this guy said to use blue painters masking tape , when i do drill through,,,,, :good2:
anyways, any thoughts could help ! ty
MarkG
1980 GT80( dirt) gone 1979 IT250  ( have)
1975 MX400(dirt) gone
1979 RD400 gone
1980 KZ1000st/ shattered right arm/ (ouch) gone thank GOD!
1995 FZR600 ( missed @gone)
1985 FJ1100 (TEL DEATH; DO WE PART)
Yes..................Tape it before you drill...Blue, or green automotive masking tape should work just fine.
And when you mount it to the bike, make sure you use the rubber washers between the fairing, and the mounting tabs.(I believe Randy has the correct ones)
Also use the CORRECT bolts with the sleeves to mount it with...........the sleeves are there to make sure you don't put too much torque on the fairing......it will crack if you don't.
poker007
Thanks Alan H.
This should go good! I appreciate the reply. Take care !
MarkG
1979 RD400 gone
