rear brake master cylinder replacement alternative
Started by giantkiller, May 02, 2013, 09:14:31 PM
I need a rear brake master cylinder. Or rebuild. I would like to put a new one on instead of fixing old. So I looked for a new one. One for a raptor 700 came up for $46. It looks just like the fj master. So I go out and compared my old fj master to the one on my raptor 700 they appear to be exactly the same. Same mounting,same outlet, even looks the same length push rod only difference I could see (other than the silver color). Is the part that screws onto the push rod.
So new OEM yamaha rear brake master for $46. Here I come.
Often wondered if the later ones would fit, great info mate :good2:
Dan, PM me your address, I have a couple rear m/c's in my parts bin...I'll send you one.
The most important thing that must match is the piston/bore size.
Usually the bore size is somewhere on the external of the cylinder.
I just checked the part numbers and it shows for FJ 84-92 only.
I know the 93 master cylinder is different.
I do stock both of the Yamaha rebuild kits.
Quote from: racerrad8 on May 02, 2013, 10:13:19 PM
Over achiever...
Quote from: FJmonkey on May 02, 2013, 10:14:59 PM
Over achiever...
Just trying to keep him safe...bigger or smaller might mean no brakes...
Quote from: racerrad8 on May 02, 2013, 10:21:05 PM
Over achiever...
Great!! Now size matters....
Thanks Randy didn't think about bore size.
Thanks Pat sent you a pm. If you have a spare. That would be great.
let me know how much for shipping
Ok, I got your PM.
What I have is a Brembo  1/2" m/c. The unit will fit, everything lines up, however unlike the FJ m/c which has a threaded holes for the mount bolts, the Brembo has smooth mount holes. You will need to thru bolt it. Some stainless cap head bolts on the inside face and stainless acorn nuts on the outside would look fine.
Still want it?
Ok, off tomorrow to UPS. You can buy me a cup of joe when we meet. Cheers!
Pat you are great, I was hoping to meet everybody at the WCR but had to cancel. Due to nephews wedding on the same weekend as the rally. If I don't show up my family will disown me. Hopefully I'll make it next year.
Thanks again
Hey Pat I keep forgetting to tell you thanks for the rear master cylinder! It looks great.  I did check the master cylinder on the 700 raptor I have. It's 1/2"also so it will work as a cheap oem replacement.
Thanks again
