Mystery sound
Started by kawabob1, April 27, 2013, 02:16:36 PM
Quote from: kawabob1 on May 25, 2013, 10:54:13 AM
I just wanted to check back with my results of my mystery noise and rear wheel play.
I installed a new chain and sprockets, that took care of the clunking noise. The wheel play was taken care of by a new set of wheel bearings from RPM Racing. I think the old bearing were original. I ended up heating the hub with an embossing tool and they tapped out easily, took about 5 minutes to warm it up enough. I also put the new bearings in the freezer for an hour before putting them back in. They tapped in easily after heating up the hub again. I put in new brake pads all around but will need to rebuild the calipers next winter. New tires, now all I need is some warm weather.. I saw a post that had a bunch of oil filters that would fit the FJ, can someone send that to me?....Thanks to everyone who gave me suggestions. Have a great day
In the old stock FJ a NAPA PS4937 I think will work. Or are you asking about spin on filters that will interchange with the oil filter conversion from RPM ?
kawabob1
Hi George thanks for getting back, the spin on would be better as that is my next mod....Bob
Look the grim reaper right in the eye...and say....someday......but not today! Life is short, live it well!
