blue dot calipers
Started by gonzajr, April 25, 2013, 12:59:06 PM
gonzajr
 gonzajr// Hello;  over the week end I looked at blue dot caliper off a first generation r1. To fit 1989 fj with stock shocks and the bolt pattern was wide compare to the one on the bike. I need better braking. Also to fit a flat bar on this bike, dose the xj upper shock tree bolt on direct.
For the Blue Dot Calipers. I used a set of 2001 R1 calipers on mine.
For handle bars this link may help. It is all in german, but they do ship to the US.
http://www.ebay.de/itm/LSL-Superbike-Adapter-Kit-YAMAHA-FJ-1100-FJ-1200-/260704178166?pt=Motorrad_Kraftradteile&hash=item3cb32e0ff6#ht_4510wt_841
HARTLESS
Quote from: aviationfred on April 25, 2013, 06:29:35 PM
So for yours is was a direct swap?
Quote from: HARTLESS on April 26, 2013, 03:17:51 PM
Yes, the calipers bolt on with no modification necessary. I put new pads in, bolted them on, attached the brake lines and bled the brakes and was ready to ride... :dance:
keand3
I used 97' blue dots calipers, and they bolted straight on too. I combined it with a R1 brake m/c from the same bike.
I have however swapt out my 86' anti dive forks with a set of 89' fork to loose the Anti dive. The 86 forks were also i bad shape.
Ken
