Nice Cheap rear rotor upgrade
Started by ccsct203, September 21, 2009, 09:06:03 PM
ccsct203
I bought a used FZR rear rotor which is solid and cross-drilled for my FJ1100/1200
At $25 it adds a great look and is a direct bolt on.
This rotor has the same bolt pattern as the front rotor on the 84,85,86.
If it's not broken, fix it anyways
thuber3040
what year fzr, and I wonder if the fronts would go on off of my 87 fzr to a 85 fj
1985 FJ1100 Finally Home
1984 FJ1100 New purchase
1978 KZ1327
1973 H2
higbonzo
Quote from: thuber3040 on September 21, 2009, 09:08:31 PM
No, they are a larger diameter.  The rears fit up into the 90's, and I pretty sure YZF 750 rears fit as well.
Later..... :bye2:
ccsct203
the fj1100  front and rear rotors are the same
cross reference the rear fj1100 Fj1200 rotor to the FZR1000 rear rotor
That will tell you the years which will fit
higbonzo
Quote from: ccsct203 on October 02, 2009, 07:27:37 PM
If this is the case you should be able to put the rear FZR1000 on the front of the 1100 and 1200 FJ/s up to 87.  As long as it is not directional.
Later.......
ccsct203
true it will fit
but the thickness may be an issue
rather thin
