New member - introduction
Started by reggit, April 22, 2013, 06:52:26 AM
reggit
OK, this is going to sound silly, but I can't get the bike seat to fit at the front.  I assume the plastic tab on the seat is supposed to fit under the bracket just forward of the battery - there doesn't seem to be enough room on mine without undertaking a little surgery!
I've put a couple of pics on of the battery area, could someone please let me know if it appears to be assembled correctly.  I've never had the seat fitted up, so have no reference as to how is should look underneath.
baldy3853
Goes under the tab next to the fuel overflow
Quote from: reggit on May 23, 2013, 05:37:24 PM
Looks like the wrong battery to me...
It is too tall to allow the seat tab to fit.
yamaha fj rider
Yes battery should be a YB14L-A2 or a 12N14-3A. Is the battery sitting all the way down in the battery box?
Kurt
93 FJ1200
FJ 09
YZ250X I still love 2 strokes
Tenere 700
FJR1300ES
BSI
it does look too tall and aren't the positive and negative posts on the wrong side?
92' FJ1200
86' FJ1200
86' FJ1200 - just bought-not started in 2 yrs
04' Suzuki DRZ 400S - cornering on knobbies
76' Husky WR250 - bought in 81', needs lots of TLC
Quote from: BSI on May 23, 2013, 08:43:32 PM
At least on my bike. The + post is on the rear brake pedal side and + and - posts are facing the rear of the bike.
BSI
Quote from: aviationfred on May 23, 2013, 09:17:27 PM
yes Fred, I didn't specify that very well, thank you for doing that...my Pos + is on the rear brake pedal side like yours and that is what I was refering to in my intial comment...but after you mention the front/rear facing of the battery posts, I believe my posts are opposite of yours and face the front of the bike?
92' FJ1200
86' FJ1200
BSI
Quote from: BSI on May 23, 2013, 09:28:23 PM
Fred, you enlightening me to the front/rear difference got me curious, so I looked...and there is a difference in the years of manf...(I'm sure this is probably old news!!!)
my 86' has the Pos+ battery post on rear brake pedal side & the battery posts are facing towards front of bike
my 92' has the Pos+ battery post on gear shift side & the battery posts are facing towards rear of bike
92' FJ1200
86' FJ1200
reggit
Thanks guys, the battery I have fitted is a YB14-A2.
Looking at the bike this morning, I think the easiest solution will be to slot the mounting box holes a little to allow it to sit a little lower in the frame.
reggit
On a 2nd look, thinking the files was a little harsh, I've just noticed that the battery box appears to be height adjustable!    DOH!
Just waiting for some penetrating oil to work its magic on a seriously corroded fastener and should be in business later today :)
bartha32
Welcome. I have had two bikes with the same DGM... identification numbers.
The exhaust had the same numbers on a riveted plaque. They were carbon silencers.
The number is proof of homologation. The sticker on the frame is the same.
Both of these engines came from Italy and were open bikes.1100- 36y and 3xw-1200.
