Fj broke down on me today :/ Help?
Started by Suselman92, April 21, 2013, 09:08:42 PM
help electrical
help
0 (0%)
electrical
3 (100%)
Total Members Voted: 3
Suselman92
So i was riding my 85 fj1100 and out of nowhere cruising in 4th gear it died..almost like i just turned the key so i pulled to the side of the road and noticed my neutral light wasnt working..so i made sure she was in neutral and it was..then noticed no brake light horn turn signals nothing..almost like it had no battery...so checked connections and were tight and clean (battery is new for the season) pushed her a block and boom light came on and fired right up rode home a block and died again..waited and waited (15 minutes) and everything came to life again..any ideas on what this could be? ive jiggled wires and nothing seems to help it come back to life so im stumped..it has 20k miles and has been garaged its whole life so all connections seem to be in really good shape.
Not positive on an 1100. On the 89' 1200 all of the lights that are effected are on the same 15 amp fuse. That is the first thing I would check.
Could be your main fuse is loose, should be on the right side near the battery in a back holder
Find a copy of the Yamaha service manual - there aree some in pdf you can download for free with some tiem and effort searching .
Take a good look at the wiring diagram  Find the common points and start there  In addition to the fuse block check the ignition switch, kill switch, etc.  Get to everyconnector you can and clean them up as best you can -a good spray of WD-40 at the least.  And be looking for corrosion and loose connections
Good luck!  And keep us posted on what you find please!
Chris W
Suselman92
Ill check them all tomorrow and let you guys know..hopefully something simple I just spent all my bike money on a yoshi pipe lol
Suselman92
Checked every fuse and connections today and still nothing...had this bike for a month and am already sick of it battery tested good has no power to anything
Suselman92
I did jump the solenoid to make sure for some reason it wasn't a bad battery and it turned over good..no spark of course but did turn over
oldktmdude
   Check the kill switch. These can give problems, particularly on the earlier models with worn switch blocks.  Pete.
1985 FJ1100 x2 (1 sold)
2009 TDM 900
1979 Kawasaki Z650 (sold)
2001 KTM 520 exc (sold)
2004 GasGas Ec300
1981 Honda CB 900 F (sold)
Suselman92
The kill switch doesn't have anything to do with lights gas gauge or horn does it?
oldktmdude
Quote from: Suselman92 on April 22, 2013, 07:01:27 PM
It does stop the neutral light but should not cancel headlight or horn. Ignition switch is another possibility.
2009 TDM 900
2004 GasGas Ec300
yamaha fj rider
This sounds like main key switch to me, dirty or worn connections inside the switch. Second thought is main power lead and always check the ground. Hope this helps.
Kurt
93 FJ1200
FJ 09
YZ250X I still love 2 strokes
Tenere 700
FJR1300ES
WR250F
