Offset countershaft sprocket.
Started by fj johnnie, April 21, 2013, 08:31:26 AM
fj johnnie
 Hein I have had the same experience. Removed the countershaft cover to find a loose sprocket. Tabs on the washer had not held the nut tight. You are correct in that it is not designed to secure clamp load. Because of this I am more cautious about ensuring it does not come loose. The inside of my sprocket cover was chewed by the sprocket. A little disconcerting to say the least. I had not ridden it yet. Thank goodness.
