Fzr front wheel/90 FJ fork upgrade.
Started by Thmsdoyle, April 15, 2013, 06:27:02 PM
Thmsdoyle
Looks like I will need to machine 1/4" off of the wheel spacer. I have not read this on anyone else's upgrade. Am I missing something, all is inline with the triple trees. If I spread the forks apart that's undo stress on the forks/seals. Any input would be great. Again thank you in advance
Tommy D.
Is the speedo drive fully seated?
Are the wheel bearings also fully seated?
Thmsdoyle
Quote from: not a lib on April 15, 2013, 06:32:32 PM
The bearings are for sure, I will need to check the speedo drive, it did pop into place when I instead it? I'll take apart and measure it.
Tommy D.
yamaha fj rider
If you have the correct parts this should fit like it was made to. What year wheel and which model fzr.
Kurt
93 FJ1200
FJ 09
YZ250X I still love 2 strokes
Tenere 700
FJR1300ES
Thmsdoyle
Hey Kurt
88 fzr 1000 wheel, 90 FJ forks.
Tommy D.
Quote from: Thmsdoyle on April 15, 2013, 07:50:43 PM
Hey Kurt
Last year I installed an 87/88 FZR1000 wheel on 89' forks, bolted right up. Make sure the spacer opposite side of the speedo hub is facing the correct way. Narrow side slips into the wheel.
Hey Kurt
Just did mine. 88 FZR / 1990 FJ. Fit perfectly. FJmonkey is probably on the right track there.
Thmsdoyle
B :sorryfinally had time to get back to some wrench time. Found the speedo drive wasn't settled all the way. Fit fine after that. :
Tommy D.
