Anything to know about this rack?
Started by Vsekvsek, April 12, 2013, 07:29:17 PM
Vsekvsek
89 fj
09 wr300 husqvarna
I have one and it works great... I have a cheap JC Whitney top box and with very slight modification fits great. You can grind the tap off in the rear and bolt anything you want to it. The top plates are around 25 - 40 bucks...        GIVI/Kappa part number f297 I think. They are hard to find here in the states. I bought mine from the same dealer.  For some reason they can't get them here in the US. Canada must have a different "pipe line" they are available in the UK also.
Vsekvsek
Finally got around and bought this rack. I am confused. Instructions just show two metal tabs coming down from side of bike to bolt rack into. Um ...only one I see is the one metal tab for the blinker. What am I missing?
89 fj
09 wr300 husqvarna
Vsekvsek
Heres a link to the instructions provided. Theres no place to bolt those things on, or am i missing something entirely?
http://old.itlcanada.com/internal2/instructions/fiches/076f297.pdf
89 fj
09 wr300 husqvarna
What you're missing is a good solid place to hang the racks from. :-/
Givi (and others) do use that blinker mount point through the rear fender and the thin sheet metal tab from the subframe.
If you can find or make some P clamps over the subframe tubes, you'll have much more secure support.
Vsekvsek
Hmm ok thanks, anyone out there have pictures of thier mounted ones? Just curious. Also i assume the blinkers disconnect easily to do this or do i need to pick up some more wire soldering supplies at hardware store?
89 fj
09 wr300 husqvarna
Quote from: Vsekvsek on July 09, 2013, 03:41:41 PM
Is this the one ?
Vsekvsek
Quote from: movenon on July 09, 2013, 04:14:44 PM
Is this the one ?
Thats the one-lol. So what did you use for the second bolt tab? I only have the blinker tab on mine. C clamp?
89 fj
09 wr300 husqvarna
Mine just happens to apart at the moment. These are the mounting points. It is plenty strong. Had a crash, destroyed the box, tweeked the rear sub frame but the rack came out 100% :good2: :good2:
Vsekvsek
Quote from: movenon on July 09, 2013, 09:09:07 PM
Perfect-thx
89 fj
09 wr300 husqvarna
Vsekvsek
Got her on and looks great, thanks all for help. Now anyone want to recommend a place that has decent prices for monolock trunks?
89 fj
09 wr300 husqvarna
Quote from: Vsekvsek on July 15, 2013, 07:07:39 PM
http://www.jcwhitney.com/garage-pro-universal-motorcycle-travel-trunks/p2010969.jcwx?filterid=c14523u0j1
The large one is a Givi knockoff, and with minor modification, will fit the Givi plate.
I've been using one for a few years now.  It's nice, and cheap, but it's not a Givi.
Quote from: not a lib on July 15, 2013, 07:22:22 PM
The large jcw box is what I had and it worked just fine. Not high quality but for less than 40.00 it is just fine. Upon impact with asphalt it desegregated but even a GIVI would had broken up so for 40 bucks I felt better for what that's worth ! I painted the orange plastic, black and removed the Iron Cross emblem and purchased a Yamaha stick on emblem off e bay. I had to do some sanding / filing on the rack ears to get the box to engage better. It was easy.
Saddleman also makes an inexpensive box that might work.
Another local FJ rider with the same rack just ground off the nubs and bolted a scooter box on and it looks good. The top plates are pretty cheap to replace if you wanted a different one.
Quote from: movenon on July 15, 2013, 09:18:51 PM
Or you could just bolt the JCW plate to the Givi rack, and save the Givi plate...   :unknown:
I keep thinking that this post was much more about a different kind of rack..  :cray:
