need help identifing a wire
Started by crzyjarmans, April 10, 2013, 11:42:35 AM
crzyjarmans
does anyone know what this wire plug is for?, With key on it has power, with key off, no power, Thanks for any help with this, It is on the right side of the bike under the seat
Shawn Jarman
jamesearthdrum
I believe it is an unused assesory plug.
peace:)james
~~~friederich nietzsche ~~~
It activated a solenoid valve on models with emissions equipment installed.
Makes a nice "switched lead" for powering accessories...
Quote from: SlowOldGuy on April 10, 2013, 12:16:25 PM
Nice information !!  TNX
crzyjarmans
Thanks for the info, i'm going to use it to install a power source for a usb port
Shawn Jarman
Quote from: crzyjarmans on April 10, 2013, 06:01:01 PM
Do you have a USB port picked out yet?  I'm considering one myself - Something marine grade or weather proof perhaps.
'93 Yamaha TDM850 (x2)
'06 KTM 200XC
'43 BSA WM20
coreyoreo
Quote from: Dads_FJ on April 10, 2013, 06:43:47 PM
+1 Shawn. I didn't even know this plug existed til I saw your post. Dug mine out (it was well hidden) & looking for a slick way to add a 12v socket also. Like to see how yours turns out.
Dads_Fj, I got my marine 12v socket off Amazon for about $5+ shipping. Not too bad.
http://www.amazon.com/Waterproof-Accessory-Lighter-Recepticle-Motorcycle/dp/B00791W8BW
Here's the dual-port USB socket I plan to use, under $5 +shipping:
http://www.amazon.com/HDE%C2%AE-Compact-Socket-Power-Adapter/dp/B004Z1VYVY/ref=sr_1_10?ie=UTF8&qid=1365642673&sr=8-10&keywords=dual+12v+usb+port
Corey
crzyjarmans
Quote from: coreyoreo on April 10, 2013, 08:15:31 PM
I haven't bought one yet, like the one you posted, have you mounted it yet?, how did it turn out
Shawn Jarman
+2  I have exactly the same one, and a similar USB plug.
coreyoreo
      Shawn, I don't have mine hooked up yet, simply because I'm trying to find the best location. The pics below show my "practice" right side inner panel, (hence the scratch marks) where the socket fit best, without getting in the way of the brake lines & what not, but the next pic shows the how tight the fit really is underneath. It's right up against the frame. ( you can see in the first pic how the frame runs underneath)
    I could move it around a bit I suppose, it would look better higher, I think, but if I move it too high, it'll bump up against the ignitor box. I could also bend the tabs a bit also so as not to put too much pressure on the socket itself.
Dan, I'd sure like to see how you mounted your 12v socket.
Again, I'm using a "practice" panel, not the one I will use. This is my first attempt at positioning.
Corey
Quote from: coreyoreo on April 10, 2013, 11:05:22 PM
Sure, but it will not help you, as it's on my GSX-R:
Looks pretty familiar, 'cept that mine is a Powerlet socket.
crzyjarmans
Thanks for the pics, I was thinking of the same location, Maybe great minds think alike :wacko3:, Only difference I was thinking was maybe on the left side, If there is enough room?, Not sure?,
Shawn Jarman
Quote from: crzyjarmans on April 11, 2013, 09:42:35 AM
If you do it on the right side, measure and drill carefully.
There's enough room there for the bottom side of the socket if you choose a shorter one and position it as shown.
crzyjarmans
found a power outlet, not on my computer, when I can, I'll post the pics of them, along with the power outlet, I got a dual USB port to plug into it, Think this will work out just fine, Thanks again for everyone's info :i_am_so_happy:
Shawn Jarman
