What size front tire should I run?
Started by HARTLESS, March 20, 2013, 11:19:32 AM
HARTLESS
120/70/17 or 120/70/17. Found a couple 120/65/17s too. Had 60s on it
And it was fine. Just wanted to know your thoughts as I am getting a new one
Quote from: HARTLESS on March 20, 2013, 11:19:32 AM
I'd get the 120/70/17.
120/70-17 is what most of us run, if you have the 3.5" wide front rim, you can run the smaller diameter 120/65 but not on the oem 3.0" rim. With the shorter sidewall you need the wider rim.
Your speedo will run higher with the 120/65 and turn in will be quicker.
Hope this helps.  Pat
I don't know if it is right or wrong but I have 120 60 17 on a 3.5. rim.  The PO had the 120 60 on the old 3 inch rim. And it
seemed to be OK, but I am more of a cruzer type rider. I get dizzy just seeing the yellow line and the edge of the road.  :unknown:
Maybe the speedo running higher will off set the rear 180 55 17... ? Or at my age the illusion of going faster will be welcome :lol:
HARTLESS
Sweet, I figured just go back to stock. I'm no racer either, plus I like to know how fast I'm really going
yamaha fj rider
Check with the tire manufacturer they have recommendations for correct size for your rim size. Avon had me use the 110/70-17. Hope this helps.
Kurt
93 FJ1200
FJ 09
YZ250X I still love 2 strokes
Tenere 700
FJR1300ES
