Fairing fixings
Started by Windmill, March 17, 2013, 04:10:31 PM
Windmill
Might have known........I must have a low immune system or something :cray:
works in your favour, means you'll  catch moditis easier  :good2: ,, dont fight it
Windmill
Too late.................. :dash1:
have you bought medication from rpm,, helps a lot
Inline filter will cause starvation problems on a graity-fed bike, you don't want to install one...
rich is right,, non fuel pump fj,s have a filter on the fuel tap/petcock  , ,
Windmill
You Guys! :wacko1: More Medication I can't handle, already have to take a bucket full before they let me out on my own.........oops :crazy:
Thanks for the tip, I did clean/rinse tank out and intend cleaning tap filter when I start sorting fuel gauge sender out. Surprised it would cause starvation problems though, having said that didn't I spot another filter in the quick release fuel pipe connector??? sure I did :unknown: I'll make sure tap filter is good then, have a spare of those too I think so will use the best one.
Exhausts are next, have been modded by someone adding new pipes to collector box to suit end cans. Pipes are too high, bashed in to avoid rear brake lever, welding really is bird ****, and they've cut the rocker off the centre stand to avoid them......... As the man said - if you can't take a joke.......... :bye2: :morning2:
